How to wear an axe/hawk safely
I make a belt sheath for every one of my hawks. The spike cover rotates allowing the hawk to be easly drawn or resheathed. Hope this helps. I carry a 17" long hawk all day in the woods and I can hardly tell that it is there..
rocketmann that is well done . I don,t understand the rotating of the spike cover but that is no biggie . Could you show a pic of the sheath beside the hawk ?
I will post the pic after work, but the spike cover is made seperatly and is attached to the sheath with a single rivet. the rivet acts as a pivit point and allows it to rotate.:D
I have to admit . I would just like to see more pics of a nice combination like that . I don,t have a set-up for rivets . The cheapo one I had would never spread the rivet evenly . Unless it was something I was doing wrong .
I must admit to never having used copper rivets which look nicer than the brass .
While we are at it . What purpose does the ring on your hawk handle serve ?
Is it merely decorative ?
Kevin, It is pretty simple to do.. I came up with this because I couldn't find a good sheath for spike hawks...This design allows the hawk to be quickly and smoothly drawn from the sheath while protecting the user at all times..
rocketmann,
that's beautiful and ingenious! If I am not wrong - you do not fasten the sheath to your belt, yes? Only tuck the hawk handle in your belt? Would the ring on the handle (what I can tell is about 4" down from the head) be a simple solution to retaining the hawk on your belt without being pushed right up each time you sit down?
17" hawk on your side all day - that's something.
the sheath has a belt loop for wearing it on a belt. If you look closely the strap that snaps over the hawk head makes a 2 inch belt loop on the back side. you can see the end of the strap going into the bottom of the sheath..crap it's hard to explain...I'll post a pic in a minute..
I am looking for a sheath for a Emerson tomahawk I just received. the case that came with is good but awkward to remove the axe quickly
keluangus, you prefer to carry a hawk/axe on your belt as opposed to a parang in the Malaysian jungle? sorry....I'm just wondering about your choice of implement. I carry a parang with me in the jungle. Axes are more for woodworking/building projects. Just my $0.02, YMMV.
keluangus said:
Kevin,
I was seriously considering the kukri - again my problem was that it does not a good machete make (too heavy), and its also pretty long and heavy for the chopping I need compared to a hatchet. In the end I realised the cutting profile of the kukri is just like our parangs! So I might as well use what's here.
Before you totally give up on "the kukri" for your purposes, you might find it helpful to look at the wide variety of them out there. (The BladeForums subforum for Himalayan Imports will help very considerably in this!) While I agree that there are several that would be very heavy and fatiguing for the uses you foresee, there is quite a range in terms of blade length and blade heaviness. When Himalayan Imports put khukuris up for sale on their forum, they usually indicate both overall length and weight, which can give you a sense of what the knives are like.
Just as kind of a starting point, the heavier "chopping-oriented" varieties include the Ang Khola models (blades sometimes half an inch thick at the spine--virtually indestructible, but heavy!), and the "Ganga Ram" variety. The "World War II" models are a bit lighter. The "Udhaipur" or "Gelbu Special" and Sirupati and Chitlangi varieties are actually pretty long, thin, and tend to have less curvature; I gather that this variety comes from parts of Nepal where the vegetation is a little lighter and (maybe) like what you're expecting to encounter. For your purposes, you really might find that an 18-inch (44 cm)-overall-length Sirupati or "Gelbu Special" might give you the lightness and speed you need for light vegetation, as well as the ability to chop wood when necessary--even if a 16-inch (40-cm)-overall Ang Khola with a half-inch-thick blade was way too heavy.
Now I'm just trying to find an inexpensive way to get a decent parang here in the 'States!
Good luck!
