How to wire this motor?
This motor shows a completely different configuration than anything I've seen before. There are three connections plus the ground (green). All connections show a rotation sign (CCW) (CW) and an 88. Don't know what that means. The wire going in, of course, has a black and white lead plus the ground. Not sure of the proper connections. I do want it going CCW. Any help to clear my befuddled mind would be appreciated.
First grab the wires and yank them out a little, it looks like they are connected with no insulation and then looped and jammed into the hole they came out of
If you're usieng CCW rotation and 110 volts, just use the left column of the diagram
All wires are labelled
Make L1 your black wire fromthe wall - connect it to p1
make L2 the wiite wire from the wall -connect it to 3 wires T2, T4, T5 all together
If you want a switch, put a switch in the way of those
I like switching both the hot and the neutral in case your outlets are connected backwards.
P2, T3, T8
connect them together
Green wire to the green base bolt of the motor
Use good wire nits, marettes
give them a hard yank, if they come off - do it again.
