Due to the shape of it, there's no curve for slicing cuts. Whenever I make a cut into something, it's the "second tip" that cuts into the medium. And because of how the blade gets thicker at that point, it drags on the blade more.
Maybe it's just me, but I just don't see the tanto style as suitable for utility or even general use. It just seems more suited for stabbing than anything else for some odd reason.
Even when there's nothing pushing against the lock, the lock does not spring out to center depth of the blade. This bothers me immensely. Maybe if I wrapped the stop pin
This may not help but have you tried loosening all the handle screws and the pivot screw and retightening everything?
Yup tried all that. I think if the pivot screw was a fraction of a mm thicker or if the liner lock had a stronger spring to it, it wouldn't be an issue. My other 0400 has no problem.
@Biggubosu
Did you buy the knife new? Mine was really sharp out of the box, it is a little odd that your knife was not that way. From what I understand the tolerances on the ZT knives are pretty close (like like a Sebenza). The problem you describe sounds like the pivot is too tight, even though you say it isn't. When I hit the flipper on mine, it flies open and locks up nicely (not too early and not too late).
You do realize that you can contact their Customer Support and get a replacement torsion bar right? I would recommend you send it in and have them look at it. What do you mean you think the stop pin needs to be thicker?
the ZT 0400's design and shape is very similar to the kershaw shallot. its basically a linerlock shallot on steroids with a tanto blade.
I was thinking the exact same thing.Just because it doesn't work for You does not mean it won't work for others.
Aluminum handles not tough? your joking right?
To the OP, its a ZT you have nothing to worry about, if something goes wrong they will take care of you.
