- Sep 16, 2002
Alonzo, DEA is correct. You just hold the wound together and glue it shut. It will naturally wear off as the wound heals. You may, however, need to apply more than one coat as it heals because a lot of movement or washing will wear it off prematurely. As far as removing it if you glue the wound wrong, use petroleum jelly. It breaks down the cyanoacryllate. Super glue is used in the ER and even in the OR when it is suitable. It is just marketed under the name Derma Bond. It has an additive to make it a longer chain of cyanoacryllate which breaks down a bit different. You can buy a version of Derma Bond at your local wal-mart etc under the Band Aid brand name called Liquid Bandage. Same thing as Derma Bond.
Mike
Mike
