Howling Rat : Swamp Rat knives
Cliff Stamp
BANNED
Specifics :
The Howling Rat is 185 g and balances about a half a cm behind the handle, neutral and very light in hand. It has a high sabre flat grind, with a small strip of unground steel along the spine. The blade is is 0.031 - 0.038" thick behind the edge, which is ground at 17-18 degrees per side. For a general use knife that angle is a solid choice, robust enough for anything outside of hardened metal, however I would cut the edge thickness down just a little. About 0.020" thick behind the edge would leave it robust enough for light to medium knot work (batoning), and any cutting work outside of heavy twisting which could induce the edge to ripple [not a concern with the current profile].
However this would lower the durability to the point that you could possibly damage it deeply [into the primary grind] on extreme hard contacts with rock or hardened metal, and it would prevent the edge from being able to take significant lateral loads, and thus its usefulness as a an overall utility tool would be lowered. The overall gain in cutting ability would be a matter of a small percentage (around 20% on binding material like woods, much less on things like ropes etc. ), so the higher thickness could easily make a lot of sense to some in regards to large durability gain vs small cutting ability loss. The major performance gain with the more narrow bevel would come in regards to ease of sharpening, as that is essentially proportional to the width ratio, so it would sharpen with about 50% less time with the much thinner bevel.
Stock testing :
The Howling Rat is shaving sharp but could be a little sharper. Under magnification (20x) the edge is smooth, so there were no rough spots, just a little roll. It scores 160 (29) g on light thread, and 1.30 (70) cm on 1/4 inch poly. For comparison, the top performance of the thread on knives of this geometry is ~100 g and about 0.25 cm with the poly [very few knives come this sharp]. Thus the push cutting sharpness is decently high, but the slicing aggression relatively low. The knife is also significantly sharper near the base of the blade than the tip. As a further test of slicing aggression, using rolls of cotton fabric as a test medium, I did some cutting with with the Howling Rat and an Opinel and Twistmaster. Both folders had very aggressive finishes, left rough by a 100 grit AO belt and both could cut the fabric on a slice with much less passes than the Swamp Rat knife. However when I just pressed all the blades through the material the Howling Rat jumped ahead. This is the tradeoff of blade finish, leave it coarse and the slicing ability jumps ahead but the push cutting ability goes down.
On to various stock work which goes beyond sharpness and into cutting ability and thus is influenced by the geometry of the blade, the Howling Rat cuts through 3/8" hemp requiring 30-32 lbs at the base and 32-34 lbs near the tip. There was little aggression on a slice taking ~28 lbs on a 2" draw, thus no significant reduction as compared to a pure push cut. It does well on whittling, taking 10.1 (0.8) slices to point a piece of 1" Basswood. The tip is of a decently robust nature, however the point penetration is still very high due to the military or penetrator tip (a short sharpened section of clip). It got on average 627 (8) pages into a phone book on a vertical stab. This is significantly better penetration on a per mass basis than the Camp Tramp (about 50%), which you would expect given the slimmer tip. All of these results (except the lack of slicing aggression) indicate well above average performance.
For comparison, I also did similar work with a 52100 MEUK made by Allen Blade and modified by Ed Caffrey. This blade is similar to the Howling Rat in size and shape [see its review for more details] with the essential difference being that the primary grind comes down to a much thinner edge. On the MEUK the blade is ~0.005" thick behind the edge which is ground at ~20 degrees [it is very difficult to measure the edge bevel precisely as it is so narrow]. The MEUK cuts the hemp rope at 29-31 lbs near the base and a much reduced 19-21 lbs near the tip. The true power of the thinner edge is exhibited on the hardwood dowel cutting where it takes only 4.5 (0.7) slices to form a point. The cost of this higher cutting ability is in the fragility of the edge profile. If the edge ever came into a forceful contact with hard bone, rock or hardened metal it could get damaged up to a quarter of an inch deep into the primary grind with the same level of impact on the Howling Rat not inducing damage exceeding the extent of the edge bevel.
[the MEUK was not used for heavy tip work as the tip is quite weak and easily bent due to a combination of soft spine due to a differential hardening and very slim geometry]
Sharpening :
After the stock testing, the knife was honed on CrO loaded leather, pushing very hard on the strop. The blade took a hair popping sharp sharpness, a slight improved compared to the initial finish. The slicing aggression was still low as you would expect given the strop compound. The blade was later tested on the fabric and on the rope with a 600 grit DMT finish [just a couple of passes on a rod] which showed a many to one improvement on slicing ability but a loss (not as extensive) on push cutting ability. For this kind of work, as Joe Talmadge has described in the past you don't need to leave the entire edge rough, I just sharpened a one inch section of the blade near the choil with the 600 grit DMT rod. That section then gets stropped along with the main section of the blade, and then retouched as necessary with a couple of passes on the rod to finish.
Chopping :
The blade has little mass and a neutral balance and thus can't chop effectively even with snap cuts around the end of the grip. There is simply nothing there to get power behind on a swing or with a wrist snap. However it can be used with a baton and thus is able to handle small woods [up to say 2.5 inches] without a large amount of effort, but you are still working many to one times slower than with something like the Camp Tramp for example. The smaller blade length on the Howling Rat hampers baton work on larger woods as multiple relief cuts are needed, and splitting even medium sized piece of wood (3-4" thick), means multiple splits are necessary. When splitting that size of wood or larger, you work around the round taking off sections until you have reduced the width to something you can split readily. You really want something longer for that class of wood, the blade length should ideally be a couple of inches longer than the maximum wood diameter to provide some free blade length so hit with the baton.
Kitchen :
On soft materials like meats, fruits and most vegetables, the Howling Rat once properly sharpened will do as well as any of the kitchen knives I own, and I own very extreme optimized blades. With the NIB finish, the blade was unable to cut well foods like plums, tomatoes and such, as there would be a lot of slipping on the tough skin because of the give of the underlying very soft tissue. On thicker foods which are solid enough to cause binding or wedging on the knife, the Howling Rat does fall behind an optimized kitchen knife. For example, it cuts through a medium size carrot with 5-7 lbs (same as the Camp Tramp), for comparison, a Japanese utility knife, at the extreme end of kitchen cutlery does it in 2.5 - 3 lbs. The force is still very low however and isn't significant enough to cause fatigue, it does limit the size of the slices you can make, you can't very very thin slices as they will break, so no see through slices for fancy presentations.
Handle :
The grip is made of a dense rubber like material which is more durable than Kraton, but far less than Micarta or G10. It has a decent texture (I would prefer it more aggressive but this does induce a trade off in regards to comfort] and deals with shock better than the more dense grip materials. It is contoured in all dimensions and is smaller in all dimensions than the handle on the Camp Tramp. It has a couple of problems though. The front of the grip is rather squarish and this really limits how much force you can use when cutting as the corners are high pressure points. Ideally the front of the handle should be blended into the blade so as to give a nice form fitting shape for an overhand grip. A longer guard would also be nice for more security in extreme circumstances. The rear butt hook is well shaped providing a strong combination of security and ergonomics.
Sheath :
The sheath is Cordura with a Kydex insert. It came with a significantly looser fit than the Camp Tramp, though not enough to induce any rattle. Nice pouch on the sheath with an elastic tie down. Secure and quality stitching.
Reprofiling :
I had intended to alter the primary grind until the edge was down to around 0.020 - 0.025", and then take it out for some really heavy wood work, knots and such, and if it fared ok there, whack it into something really bad like a nail into a piece of wood. Plans being wonderful and all, when I started grinding I bled the edge back into the primary grind before I knew what I was doing, force of habit I guess. Now the knife was a basic replica of Luke's modified BA3 I described awhile back. Just as seen on that knife, the changed profile induced a large increase in cutting performance, but I would not want to hit the edge off of anything hard now. This combination doesn't seem that coherent to me, I would prefer the original profile, or a very different overall one like the Deerhunter from A.G. Russell, more optimized designs. It is out on loan now to get some use on it with the new profile, mainly durability reflections.
Ref :
http://www.swampratknives.com/
-Cliff
Nice review Cliff!! :D
The handle on my Bandicoot, which I chose due to its smaller aspect ratio and finer point, is the most comfortable handle for a small knife that I've ever held. It just fits perfectly :)
I've been impressed with my coot a great deal, and it seems to corrolate with your results.
Cliff,
Nice. I think the comparison between the Meuk and HR is an apt one, as is a direct comparison with the BAIII.
Cliff,
Could you compare the Howling Rat to the Busse Basic n°5 (or European n°4)?
Originally posted by Cliff Stamp
...no see through slices for fancy presentations...
As I feared, your recent exposure to the Martha Stewart line has begun to impact your perspective to the point of reordering critical priorities in your methodology. May I suggest a little quality time spent with your Battle Mistress and a few cords of frozen spruce, to stave off the progression of this diabolical degeneration?
Eric :
In this class of knives I have many that are solid performers so comparisons are readily available. The MEUK is an interesting compromise between cutting ability and durability. It is at about the limit of durability for heavy use as it is able to handle up to and including splitting of light wood (with a lot of care around knots).
Using the Deerhunters lately it became apparent that I need to include a cutting stock test that is more primary grind influenced, as the Deerhunter doesn't do significantly better than the MEUK on the dowel or the cord. Cardboard is obvious, but I don't have that on hand on a regular basis in consistent quantities, I am thinking of thick vegetables like carrots or turnips.
Outside of kitchen use though, there isn't a lot normally that produces these kinds of forces, most brush / weeds here are not solid enough to notice a difference in primary geometry. Cardboard and really thick ropes are about it. In labor work there are lots though, insulation being the worst to cut, which is why carpenters knives are really thin.
Neo, I am not familiar with the Basic Number 5 or Euro number four.
Will, it is that time of year, last years wood has been cut, limbed, bucked and stacked. However in few months next years wood will start to come down, depending on how much longer we have to put up with 30 cm snow falls. I think I'll treat myself to a new felling axe, maybe the GB, or Iltis or possibly both.
-Cliff
Cliff,
IIRC, the MEUK is made of somewhat thinner blade stock than the HR, and both are flat ground. Based upon this alone, I would expect the MEUK to be a better slicer. Also, doesn't the black crinkle coat on the HR provide a bit of extra friction in the cutting?
I have wondered if cleaning the coating off of the HR would improve its cutting properties, particularly with tasks where the flat of the blade contacts the medium to any degree.
Geode :
... the MEUK is made of somewhat thinner blade stock than the HR, and both are flat ground. Based upon this alone, I would expect the MEUK to be a better slicer.
The MEUK is indeed slightly thinner, ~0.155" thick at the spine and it also has more of a distal taper than the 3/16" Howling Rat. However this doesn't induce much of a difference in cutting ability on materials like rope, wood and the like. The performance on such materials (ballpark) goes like 90% edge angle, 9% edge thickness, 0.9% spine thickness.
As an example, the 0.080" thick Deerhunter and the 0.155" MEUK will perform at near identical levels on cutting ropes, whittling woods, slicing light cardboard (1/8") and various vegetables. Getting specific, both could slice the cardboard (with the ridges which is easier than through them) at ~2 lbs. On carrots, both would max out at 5-7 lbs through the middle of the carrot, but the MEUK would actually go lower towards the end of the cut.
This was interesting enough for me to look at it in detail. What was happening is that as the MEUK approached the end of the cut, the greater wedging action would force the carrot to split and it would open up before the edge. You can readily feel it as the blade suddenly starts melting through the carrot as if it wasn't there. I noticed the same thing when using the Martha Stewart Chef's knife awhile back. The thinner blade stock of that knife actually induced more binding on certain vegetables.
This is common knowledge is wood chopping tools, if the blades are too thin, you will lose cutting ability as there isn't enough splitting action induced to cause the blades to clear out the woods on the relief chop. You can see something similar on cutting heavy cord. You reach a maximim in the bottom part of the cut but the force can drop off near the very end as the rope falls away from the sides of the blade. It is not as significant as on the carrots though as ropes doesn't "split" like the vegetables do.
Yes, but it isn't a significant effect in general.
-Cliff
Thanks Cliff for the review,
I just purchased a Howling Rat and am waiting fo it's arrival. It good to know the strengths and weaknesses of the knife even before I receive it. :D
Thanks, the Swamp Rat line is starting to fill out nicely and is providing some solid blades. Now we just need a 12-14" brush blade, and a nice solid folder.
-Cliff
Cliff,
Nice review of the HR. I just bought this knife and its on its way home. I had to decide between the HR and Ranger RD4. After reading your and some other reviews I made my decision. I think the HR is a more handy around utility/outdoor and the RD4 more a small chopper.
I was also looking for the Busse Bagger Attack whit E-handle, but that one is not in my budget and very hard to get.
Can you (or somebody ells) tell us more about the differences between the Busse BA and the SRKW HR whit some pro’s en con’s.
Micarta does little to dampen shock but the Resiprene C is quite effective, it also insulated from temperatures. However Micarta is much more resistant to tears, cuts and abrasions, but I have seen little functional effect and you can heat seal Resiprene C. I have seen some loosening in continued heavy prying, but this is extreme and noted with a much larger blade, Camp Tramp. I prefer Resiprene C though it is generally regarded as inferior.
The blades are similar in shape with the Howling Rat having a large index finger choil which makes some point work easier but reduces heavy power cutting because it puts the edge far infront of the handle and the grip ergonomics are not high in a forward grip in heavy stress due to the squarish end of the handle and lack of rounding in the index finger choil. I prefer edges on small knives to run right back to the handle like Boye does it on his drop point hunters. A small choil notch can be useful for aesthetic purposes as otherwise you will note the grind start to drift at that region.
In regards to general cutting ability, the knives are similar in grind and you can easily adjust the edge bevels to optomize to task. SR101 does grind a lot easier than INFI which usually isn't a factor unless you want to do heavy reshaping. The main thing you will likely notice is that INFI is *much* more corrosion resistant and doesn't take a patina whereas SR101 will readily if you cut acidic foods.
It is also easier to lash the BA to a stick with the multiple attachment points through the holes and the front talon hole also serves as a point of attachment for a guard/laynard. The full tang of the BA also makes it more suitable for some work like heavy point splitting because hammering on the end of the Howling Rat handle will deform the eye.
-Cliff
