Cliff Stamp
BANNED
- Oct 5, 1998
Ilovetoolsteel said:I went to his website except to mention that he uses it.
Email him and see if he uses it only for the reasons you describe.
But the discussion wasn't about Phil Wilson, it was about Buck and their 420hc.
You generalized to the steel, and the steel is the same between Buck and Wilson. If it is worthless for Buck it would be for Wilson and the reverse is true as well obviously. There are also a lot of other stainless steels (and even tool steels) of the same general class - not optimally hard or wear resistant but tougher, more ductile and with a finer carbide structure. Now there will be a difference in the heat treatment, between Buck/Wilson, yes, but it would be hard to argue Buck is so incompetent in that regard given the massive number of people who use Bos.
Furthermore even Buck admits they went to the steel not for any customer based performance related issues but for ease of manufacture. You can try to ignore that fact but that's why Buck uses 420hc.
No one is ignoring it. You are ignoring the fact that this isn't unique to 420HC. When S30V first came out it was clear that this was to allow knifemakers to make knives easier, not that it actually made better knives than S90V. S30V was just cheaper, easier to grind and less demanding to heat treat. Similar now with the promotion of CPM-154CM, it allows easier grindability than S30V and isn't as expensive, not that it actually makes better knives. Note how many people who forge knives choose steels and promote them strongly due to being "forgivable" in forging/hardening.
If I were inclined to make a tool like a knife, designed for say, Cutting stuff? 420hc would be the least desirable option?
That would depend on what you were cutting and how. Just like for some knives L6 is a much better knife than M2 and for some other knives it reverses.
I am criticizing 420hc solely on it's merits. It is inferior as a cutlery steel. It fails to meet the reasonable minimum performance requirements of what is expected from a knife. Edge holding is paramount among those requirements.
Edge holding isn't so trivial an aspect to allow such a statement. 420HC doesn't have inferior edge holding to ATS-34 for example. It does for some cutting but not for others. It is softer and less wear resistant than ATS-34, but also isn't as prone to carbide tear out at fine angles, it is much more ductile, corrosion resistant and significantly tougher.
-Cliff
