Evan Miner
Maker
- Nov 24, 2011
Iv recently got my hands on some 1/8 inch 1080. I'm trying to make a 12 fillet knife with this. It tried a few ways to quench this material with minimal results. A little in site as to what iv tried. The first attempt was fully profiled and ground to spec I heated it in my forge to a fee shades above critical and quenched in warm oil (thermal fluid for industrial heat transfer systems) my results were a hardened edge but not hard enough to bend and return it stay bent after a little force was applied. So I tried this a few times thinking that maybe I didn't get the right temp to fully harden after a few more attempts I figured I wasn't cooling quick enough so I tried the same blade with a water quench. I got the fully hardened blade I wanted but with consequences the blade warped heavily. After straightening the blade I attempted it a second time this time I got a ping which I figured as it cracked. So I snapped the blade and examined the gain the gain was still nice and fine so I figure I have the temp right now I just have to get my quench speed right. So I profiled out a second blade but this time I didn't grind my bevels leaving it the full 1/8" stock in hopes it wouldn't warp only to find it warped worse then the first attempt. I snapped this one trying to straighten it right after quench. I took to long attempt 3 I did the same as the 2nd in process with the same results but this time I figured I'd temper it and work on straightens it then fail. Now I'm on here to see what I can do to fully harden this steel and minimize my warps. Any help would be grea. Thank you for your time.
