- Dec 17, 2007
Hi All,
Started working in 154-CM and liking the material but I am having an issue with the foil sticking to the blade when HT. I am using a Paragon furnace with controller so I am confident that the temps are correct. Double wrap in 309 stainless .002(good to 2240 degrees) cook to 1950. Here is the question. Into the first wrap with the knife goes a small piece of paper to burn off the oxygen in the process I believe it is causing the foil to draw in on its self and contact the blade where it leaves a stain and is then hard to peel away from the blade. It looks something like a hammon but in the wrong and arbitrary places. The second wrap with out any paper in it maintains its shape and does not stick to the first wrap. Is there a solution here perhaps leaving the paper out of the first wrap? Is it possible the foil it's self is no good? Any input here would be appreciated.
Thanks, Ken
Thanks, Ken
