- Feb 25, 2011
Hi folks,
Let me start of by saying that I recognize that the post title is a bit of an oxymoron, but it seems like i'm stupid enough to try this anyways.
I've got my hands on a sizable piece of 1/16" bandsaw steel. After some reading, i've found that old saw blades (without carbeurized inserts) are often 15n20 or 10XX.
I know that HTing mystery steel is a crapshoot, and i'll more than likely end up trashing this and buying a piece of steel from Aldo, but considering that i'm on vacation and have the steel on hand, i figured it's worth my while to give this a shot.
My HT gear consists of a charcoal forge, toaster oven w/oven thermometer, and canola oil.
So here is the plan for HT.
Profile and drill a 5 inch blade santoku.
Heat to non magnetic then anneal in wood ash.
heat to non magnetic + a little, then quench edge first in warm canola.
Temper for 1 hour around 350.
Grind in convex edge and test on brass rod.
Temper twice more for one hour cycles, bumping temperature up 25 degrees as necessary until edge flex test provides adequate results.
My main questions are:
1) Is it necessary to anneal multiple times?
2) Should I anneal at non magnetic or slightly hotter?
3) Should I quench multiple times?
4) For this style of knife, should I just edge quench, or quench edge first, then quench the entire blade.
Thats about it.
Thanks for your help.
Adin
Thats about it.
Adin
