HT W2 file with simpel tools?
Im going to a night class in blacksmithing. The blacksmith asked me to bring scrap steel ( similar to 1070, 1084, 01, W2). I got a batch of old worn out files that i just found out where made out of W2 tool steel.
There will be a coal forge, water, oil, magnets.
How would you heat treat it?
If it really is W2, a 1450 or 1475 degree soak for AT LEAST 10 minutes will work perfect. Quench in oil (oil is safer than water, but water certainly can be used on W2) that has been warmed to 120 or so. You certainly can quench in room temp oil. Temper in oven at about 425 degrees for about a 60 rockwell. Perfect.
I believe the higher carbon steels lose their magnetism around 1414 F. This point varies just slightly between steels, but it is around 1414 F.
