Sale is over for the multi tools but everything else is still available for discount! Spinners, knives, etc are all still marked down.
These don't come around often but I have a big ol' batch of Titanium BeerRambits in either Satin or Anodized finishes. Just specify via the drop down menu on the webstore. Anodizing finishes are heat anodized only so I'm limited to the colors available from the drop down menu. Thanks!
Buy these now at my webstore
The BeerRambit is a karambit style bottle opener. Allowing you to spin it around on your finger and perform tricks you see people do with real karambits, but safely! Made from USA sourced Titanium now with a 1/4" hex driver and 1.5" phillips/flathead driver bit. Has a scraper/pry-bar ground down at the front and a spike on the ring which can aid in opening boxes or impact "work". This model also includes a slot to be used as a dangler from the belt loop or pocket. Comes with two O-rings and driver bit with birth certificate. Hand finished by me in my small shop with USA sourced materials and water jetting.
Length - 4.5"
Width - 1.5"
Thickness - 0.25"
Bit Size - 2"
Ring Size - 0.95"
Hex Size - 0.25"
Bit Type - Phillips/Slotted
Here are some photos:
I also have a variety of spinners from my V2 model to my V3 multi tools. They are karambit inspired as well allowing you to spin them or flip them with either the rings or central bearing. CNC machined in the USA from either Stainless, Aluminum, or Brass.
These ship with blue loctite, thank you note, and small instructions.
V3 Features:
Features:
Multiple fidgeting uses
Multi tool functionality such as carabiner and bottle opener
All integral design
Smooth inner rings
Machined chamfered edges
Durable aircraft grade aluminum
0.75" diameter finger holes
Upgraded R188 bearings come with finger pads
V2 Features:
Features:
All integral design
Smooth inner rings
Durable materials such as SS and brass
0.75" diameter holes
Standard 608 skate bearing can accept custom buttons/caps
Length - 4.5"
Width - 1.5"
Thickness - 0.25"
Bit Size - 2"
Ring Size - 0.95"
Hex Size - 0.25"
V3 Features:
Features:
All integral design
Smooth inner rings
V2 Features:
Features:
All integral design
Smooth inner rings
