- Oct 4, 2011
I recently started working with 1084 from Aldo.
I forged and ground a 9.5 inch Chef's Knife (my 5th knife); didn't grind bevels, just the distal taper. 2.5mm thick at the heel, about 1.5mm thick near the tip. Overall height at the heel 2.5 inches. Heated above non-magnetic as even as I possibly could in the forge, and quenched with back-and-forward agitation in 140 degree F canola. Tempered at 400 F for one hour, twice.
By nature of the quench container that I used, I quenched the main body of the blade first, then after the color faded from the spine and tang, quenched the whole blade itself afterward. This means that I had to quench with the blade angling downward, where less of the heel actually made contact with the oil initially; however, the heel DID contact the quench, about halfway up towards the spine.
I tested for HRC today in my metallurgy class (completely separate from the knifemaking), after cleaning up the scale and whatnot. At the heel, 30 HRC. One inch forward, 45 HRC. Another inch forward, 60 HRC. The rest to the tip was 60 HRC. I was quite sure that my angled semi-edge quench caused the heel to be softer.
My metallurgy professor, who has a Ph.D in the field and had taught at the University for decades, asked me details about the knife etc, and I told him it was 1084 quenched in oil. He said I went wrong quenching it in oil, and that it should have been quenched in water. Even if I had gotten 60 HRC along the blade, it was probably only on the surface he told me.
So, I'm kind of thrown off by this. Thrown off first of all that the heat treat I thought succeeded was actually not that great, and also by the case my professor made, mainly because for our craft, it's preached by the majority of knifemakers to quench in a fast oil rather than water for a 10XX steel.
Really looking forward to responses. Thanks for your time.
