- Jul 15, 2000
Quiet Storm said:
LMAO!
That Dodge dually 1 ton came out of that wreck in much better shape than that Hummer!
I'm not suprised in the least.
Quiet Storm said:
Andrew Lynch said:I wish LandRover, Toyota, etc. would offer bare-bone versions of their off-road vehicles. I would be first in line.
Something like this...powells85 said:A video I saw involving a H2 was where it snapped a tie rod doing some small rock/trail driving:barf:
CODE 3 said:LMAO!
SAKguy said:H2 is junk. It is on the same frame as a Chevy Yukon or GMC Suburban. That's why the rear axle is just a regular straight axle with the center differential.
The H1 Hummers rock. They have 4 wheel independant suspension.
I could make a huge long list of why H2 is junk compared to H1. I'm sure H3 is even more "yuppie friendly".
I'll take an H1 or a military Hum-Vee any day over the latter Hummers.
m1marty said:S.U.V. = Stupid Urban Vanity.....![]()
I have never driven a civilian H1 nor the H2, but I have made a military Humvee do some REALLY amazing things. I think the civilian ones are more a status symbol than anything else.
Without getting too much into it (in response to someones earlier post) I would much rather have solid axles vs independant for a few reasons. The biggest ones are "stronger", easier to lift a truck with them vs ind. and a solid axle acts as a lever ie. driving in ruts or other off camber terrain, one tire stuffs into the fenderwell while the other is forced toward the ground. With an ind. set up, if one is stuffed, the other can just hang there or barely touch the ground. I have turned a 4WD Humvee into a no wheel drive sitting lump during some pretty hairy off roading. This can be somewhat fixed by a true locker diff, not the crummy "torsion biasing" diff that is in the Military ones. That still leaves you with the traction problem though.
No keep in mind your average person will never really use a 4WD to the extreme, but what I said about ind. axles is true even for the guy/gal who is out camping, going off roading once or twice a year etc. I have built and used 4WD's to their breaking point and then some, so I have a little background in this. Just my .02 pesos (less than 1/10 cent at current exchange rate) and as always, Your Mileage May Vary.
BTW- My brother has a 1988 Toyota LandCruiser that is pretty much stock minus some basic bolt-ons/ins. Inline 6 and a 4spd. That thing has survived everything we have thrown at it in the Colorado Rockies over the last 6 years with only minor breakage (w/152K on the clock) IMHO, one of the toughest rigs out there.
My last 4WD was a '73 Blazer (full convert., nice in the summer!) Built as follows:SAKguy said:You are somewhat correct about the straight axle vs. the independant suspension.
Also, the "pumpkins" like to get hung up on freaking everything when you are off-roading.
The only good answer would be to put "tall" tires on a vehicle with a standard axle, which is stupid and merely just for looks.![]()
