You don't need a saw or an ax to cut through the pelvis. You can cut around the anus and pull the rectum out from the gut cavity side. You don't need a heavy point to pop out joints. It takes only a few seconds to cut the ligaments to dissect the joints. A blade with a lot of belly is not needed for skinning. As stated above, most skinning is done by pulling the skin. Taxidermists do not use heavily swept blades to do detail skinning. Almost to a person, they use relatively small, pointy knives with little belly. I use a caping knife for all tasks up to and including quartering deer sized game.
This is the one I use Cub Bear
For de-boning and cutting steaks I prefer a larger knife, but for the majority of the processing (gutting, skinning, quartering) I find a large blade to be a hindrance and not a benefit.
And please don't get a knife with a "gut hook" on the back of the blade. It makes the knife less useful for all tasks except for opening the gut cavity- and that can be done in a few seconds with a bit of care. Ride your index finger on the back of the blade with the tip of your finger "indexed" on the tip of the blade. Insert your blade- edge up- into the cavity, just under the muscle that lines it. Your finger will push the gut out of the way as you make your cut.
Pay attention, this man knows his stuff.
