I think I only peed once so we still werent' taking in a lot. IMO sometimes you almost can't take in enough to stay hydrated unless you really work on it, but it's mega important.
Yeah, we need to be sipping water continuously to help keep body temp regulated. Sometimes it's hard to do that when you're busy(or hiking) and your mind is occupied, because you don't think about it, and don't "feel thirsty". Then when you do get overheated, you end up guzzling a lot at once trying to get cooled off, which can be bad for a number of reasons. I still do this sometimes even after having worked for years in extreme temperatures, and knowing better, because I hate stopping in the middle of working on something.
That might be fine on the job, or mowing the grass, but on the trail it can be dangerous, especially if you were estimating your ability to make the next water source(and maybe even skipped a chance to fill up, BTDT) based on having used very little water to that point-and then suddenly those few liters you were carrying are gone when your body demands cooling to keep functioning.
I see a lot of people making little survival kits where they can boil water and/or carrying Micropur tabs, but little talk of filters and purifiers. I carry Micropur tabs and a SS cup that I can boil water in, too, but those things take time, and are not conducive to topping off your water as the opportunity presents itself. A water filter that pumps directly into your bottles like the Katadyn Hiker makes for quick and easy refills regardless of how much water is or isn't left in them.
Water usually isn't a problem around here, but I have the old PUR Voyageur pump with Katadyn Hiker filter, and have been trying to get in the habit of tanking up and topping off whenever I stray from a waterway.
This time of year I consider that filter my most important piece of gear. I carry a collapsible bucket in case I have to get water from a trickle somewhere, and use a paper coffee filter in addition to the stock pre-filter to help ensure against clogging.
Anything that helps the water keep coming is a good thing, IMO.
However, do other people who are accustomed to dryer climates - desert dwellers - Tuareg/Bedouin peoples - require as much hydration as those of us from "moister" climates?
Humidity makes both heat and cold much worse.
In high humidity, we don't get the evaporative cooling effect during hot weather because of the moisture content in the air, and sweating doesn't cool us down-but we keep sweating more and more as our bodies try to cool themselves.
That's what happened to me yesterday. It was like every pore in my body opened up and started pouring water, but I had to get out of the sun and pour cold water over myself to keep from falling out, because sweating alone wasn't enough to regulate my body's temperature.
I don't think it's possible to put too much emphasis on proper hydration and maintaining electrolyte levels at any time, but especially for those of us in regions that combine high temps with high humidity.
