- Aug 30, 2012
I've always used canteens but since my new pack comes set up with a pocket and holes in the flaps, I would like to try a hydration bladder. What are the top two or three that I should look at? Thanks.
I say the mil one because it already comes with the insulated tube. Helpful against sunlight.
If you just want to try a bladder to see if you like it, with minimal expense, consider the Outdoor Research unit from Walmart. You can always upgrade if you like the concept and it works for you. If not, you haven't spent much.
Source makes some good bladders, I've had a couple. not perfectly taste free, but not as bad as some others (and I'm sure they are better now) and they are at a reasonable price. Depending on your bag, and the setup, think about how you are going to fill it, and weather or not a quick detach hose will be important, If you like Ice, then a zip top is good, and if you are looking at a screw lid, many, but not all fit the "nalgene" standard which means MSR and some other filters will screw on. You might want to start with a cheaper one just to see how much capacity reasonably fits, as well as how it rides once its half full. I've had some carriers that were not so great once the sloshing started.
