Great tips! Thanks!Easy trick without adding weight and bulk of the insulated tube: blow your water back into your bladder. Works in the heat and cold :thumbup:
Other bladder tricks I learned along the way:
Fill your bladder with 1L of water, lay flat with lid open and propped up out of reach of water (and no water in hose), freeze overnight. Fill before your trip. If you're using an insulated bladder pocket, you have cold water all day.
After you've filled the bladder, invert and put pressure on the bladder to push air out through hose. Sloshing eliminated.
