Willie, I am concerned that with what you are ordering, you will not achieve success due to incorrect calculations. I want to make sure you understand everything involved, so let me in my fumbling way to try to produce a clear technical explanation.
Here is roughly what you are wanting to achieve, as I understand it.
5" Cylinder
2" Rod
You'll need to pressurize the oil to 2500 PSI
To achieve 49,087 lbs push force
That would be nearly 25 tons, an adequate working force for a bladesmith press.
If you go with a 16GPM single stage pump, you will need a BIG motor to pressurize the oil to 2500 PSI at that flow rate.
HP required to produce 2500 PSI at 16 GPM, 5" cylinder: 25-27 according to multiple online calculators.
It would be a super badass press, since it never slows down and you'd be getting 25 tons of press at a high ram speed, right into your steel. This is how Larry Langdon and some others are making forging presses. It costs.
If you try to hook a 5 hp 3450 rpm motor to that pump, it will never build the pressure you need.
In fact it looks as though you'd only build about 450 psi with 5 hp, at 16 gpm.
This is the pump that I run. Although it is nominally 16 GPM, let me lay out how it can work for me, at 5hp.
http://www.surpluscenter.com/Hydrau...r-Pumps/16-GPM-2-STAGE-HYD-PUMP-9-7503-16.axd
First let's run the numbers for this pump, using a 3450 RPM motor like most would.
7.13 hp is required to build 650 psi for the low pressure/high speed stage (16 GPM) with that pump, and the high pressure/low speed stage (4 gpm) will require 6.85 hp. Your 5 hp 3450 RPM motor will almost accomplish that. A 7.5 HP 3450 RPM motor would work great, and perhaps you'll want to consider that. Ram speed would be 3.1 IPS in the 16 GPM stage, pretty nice!
Now let's look at using a 5 hp 1725 RPM motor with that pump. The important thing to understand is that halving the speed of the motor means that the pump output will be halved. The displacement of the pump remains the same, but in a given amount of time, it spins half the amount of rotations, so
the GPM pumped will be half of the pump's rating, which is given at 3450 RPM.
This has the fortunate effect of more or less halving the HP required, and the less desirable effect of halving the ram speed produced.
Here are the numbers for my system, then- in which the pump is effectively 8/2 GPM.
650 PSI, 8 GPM, low pressure/hi flo stage: 3.6 HP required.
2500 PSI, 2 GPM, hi pressure/low flo stage: 3.43 HP required.
You can see that in that scenario, a 5 hp motor fills the bill quite handily. Here are the ram speeds I achieve, which I find acceptable.
0.4 inches per second ram speed, high pressure/25 tons, push
1.6 extend (push) speed at 650 psi low pressure stage
1.9 retract speed at 650 psi.
Partly what drove my choice to build like I did, was that I found this killer 5hp 1725 TEFC Baldor motor secondhand for $100 when I was gearing up for my build. Then I read that Don Hanson uses the same system, which bolstered my confidence to try it. Don also mentioned that the press is quieter at 1725 RPM than at 3450, and that is true. I wear hearing protection anyway, but it's a bit of an added plus.
Here is a link to calculators for hydraulic cylinder push/pull force, and ram speed:
http://www.baumhydraulics.com/pages.php?pageid=4
Here's a link to a calculator for required motor HP, at various PSI:
http://www.bbhydraulics.com/pumpcalculator3.html
I hope that all of the above is somewhat clearer than mud. I'd be happy to kick it around further if necessary for a complete understanding.
