Has anyone tried an air over hydraulic press like the Bonny doom 20ton jewelry press. They look big enough, are 20ton and much smaller than most I've seen.
Thanks
Firstly the Bonnie Doon press is horribly overpriced in my opinion.
$1,000 for a 20 ton bottle jack and small frame.
$3,000 for the same small frame and a wee little electric jack
For that price, you could build one, or almost buy one.
I've seen some use a Harbour Freight air over hydraulic jack in a small press frame, but it's much much cheaper.
Secondly, it's too slow.
forging presses are desired to be in the 1 to 2 inch per second ram speed.
The idea is to get several pressings in before the work cools too much.
There is a book on forging presses and lots of pics and info here
$1-3000 should buy you a homebuilt "real" smithing press even if you have to source out some of the work like welding, it also buys a lot of fly press. I think I've seen used smithing presses for sale on ABANA for that price range also.
Or, you can get a 30 ton or more log splitter and convert it for $1500 or less pretty easily. If you could find one for sale with an electric motor rather than gas, it would save some money and work.
