- Dec 15, 2009
Edit: After reading/thinking/asking more, I don't think that tank is going to work. 2" seems too big to neck down to a 3/4" port. Will a 1" hose clamp (safely) on to a 3/4" inlet at the pump side? Or do i need a tank with a 3/4" suction line opening?
Hey guys,
I'm sourcing parts for my hydraulic build still, and I've run into a snag. I have most things picked out finally, but the best tank I've found for the money is this:
http://www.northerntool.com/shop/tools/product_200466865_200466865
Which has a 1" return port and 2" suction port.
Baton's book highly recommends various filters, all of which I've sourced except the return line filter. They all seem to be either 3/4" NPT or 1 1/4" NPT - no 1 INCH ones.
Northern recommended this: http://www.northerntool.com/shop/tools/product_124313_124313
Which is a fuel filter designed for gas/diesel.. I'm not sure if it's appropriate for hydraulic oil, but it IS 1".
Princess Auto has a couple tanks.. but they don't list any of the specs hardly so I can't be sure filters will match etc. I'm ordering the cylinder from northern anyway, so I can get the rest of the items there that I'm sure will match. The only wildcard is this dang filter.
Can someone shed some light on this? Or should I just look for another tank/filters setup? Or should I skip the return line filter and hope the suction strainer in the tank will pick up any crud on the return trip to the pump?
Thanks all!
Afterthought: Will the 2" suction be a problem? It seems pumps use the 3/4" inlet.
Hey guys,
Thanks all!
