- Jun 11, 2006
Thanks to Stacy who put this bug in my ear. I have been studying the process of using a hydrocarbon as a flux for welding. After I bit of reading its apparent that it works great but I started wondering why. So I dusted off the chemistry side of my brain and started researching. So let's see You grind the surfaces of the steel and stack. Then wire or welded the stack together. Then it gets a bath in a hydrocarbon "kerosene" bucket. Next into the forge to start heating up. The fuel will burn/decompose as it heats leaving carbon deposits on and between the layers. Now we come to the catchy part. It was said that the carbon acts as an oxygen barrier but I'm thinking it's more complicated then that and her's why. First off if carbon was just shealding the oxygen from the steel then we could have carbon trapped between the layers which would be visible on an etch. Next is looking at the carbon and the require forge atmosphere needed to make this process work. The fact that the forge is run with a reducing atmosphere which means there is more fuel then available oxygen is another clue. The next key is the carbon, in searching I found "The industry standard test for carbon content in graphite samples is to heat them to 1000C in a muffle furnace. At that temperature the graphite will burn off in a normal air environment". So carbon will burn at 1832° when in the presents of oxygen, so having a reducing atmosphere means we are not burning the carbon as it would in an oxidizing environment. So this got me looking at the actual numbers and it all made perfect sense. Your coating the surface with carbon and heating. In the forge your not building any scale because of the fuel rich environment. This environment keeps the carbon from burning off and alows it to become super heated to the tune of say 2300°. You pull the billet from the forge and the carbon is instantly exposed to oxygen rich environment which means it should burn. Now the linchpin to this entire operation lies in the production of iron. Iron is mined as ore which is iron oxide, basically the same stuff we are trying to prevent from foruming between the layers in the pre welded billet. So how is iron ore turned into steel, WITH CARBON. The entire process in a nut shell is this. Carbon is burned with oxygen at high temps creating not C02 but just C0. This Carbon monoxide passes across and through the iron oxide and once the iron oxide heats up the oxygen jumps ship and attaches to the carbon monoxide creating carbon dioxide leaving iron behind. This also seams to happen at 1000°c according to research. So what I think is happening is once the billet is pulled from the reducing forge environment into the oxygen rich air the carbon flashes and creates carbon monoxide which then reacts with the steels surface pulling out any and all available oxygen from any scale that might of just formed and quickly turns it back to iron. This means no carbon left between the layers and a very pure and clean surface to weld that's shelled with CO2. And the formula below spells it all out.
C2 + O2 ---> 2CO + heat
3CO + Fe2O3 + heat ----> 2Fe + 3CO2
What do you guys think, am I off my rocker and thinking to much into this?
Edit, my eyes where just opened with fluxless welding.
