- Feb 4, 2005
I'm open to suggestion...
I understand this isn't answering your direct question...
My opinion is, if I absolutely had to use a substitute quench oil (an oil not specifically designed to do the job to best advantage), I would use canola oil and I would replace it fairly frequently.
I can't tell you exactly what the replacement schedule range would be or all of what to look for in deciding. I know I had failed quenches in vegetable oil but I don't know the exact causes. I believe it was oxidizing of the oil through repeated heating, thereby changing the cooling curve of the oil.
I don't know if you know Scott Mckenzie. He is Houghton International's metallurgist and quenchant specialist. Scott posts on both BS and SFI ~metallurgy. He put up a post on BS a while back stating, of the substitute quench mediums, canola oil best matched the ideal cooling curves (fast in the beginning and slow at the end) and is in the fast range for quench oils.
I don't know how much longer quench oil will last over the various substitutes. I feel it is quite some little bit.
Mike
