Hi,
But I also disagree with the idea that hypothermia can be avoided by caloric intake, exercise, etc.
Well it's quite simple. Core temps are just like a bank account. You have income, and you have bills and expenses. If you have more income than expenses, you pile up heat. Otherwise, you get cold.
In a cold setup (environment colder than your body), 4 things pump heat away from you :
- conduction
- convection
- radiation
- evaporation
What produces heat is :
- basal metabolic rate, which is a complex thing :
--- it gets slower and slower as you get hypothermic (> 35°C)
--- it gets faster when you're just slightly cold (thanks to adrenalin)
--- it's sped up by caloric intake
- brown adipose cells (fat furnaces that produce heat from fat, leaving your glycogen stores alone)
- energy expenditure (exercise or shivering) : this is a short term solution only. At some point you're exhausted and need to rest.
I've read Moine's post on the other thread, and feel those can mitigate the onset--but not prevent.
Calories will fuel the shivering and thus delay the onset of hypothermia. But if you do not get to a context where your basal metabolic rate + brown fat cells heat production will be enought to keep your core temps stable, eventually you'll become exhausted and stop shivering (or exercising).
But we're not talking about pools and recreation, necessarily. Add a good afternoon rain to a 60-degree day, and you can find yourself shivering just as fast. A brief shiver is not the onset of hypothermia--but if your shivering lasts more than about three-to-five seconds, you're at risk right there.
You're at risk whenever you have to shiver or exercise in order to keep your core temp stable. This means you should seek to block away the Big Bad Motherf... Four (BBMFF as some army guys would put it
- conduction
- convection
- radiation
- evaporation
If you can calmly lay down and do nothing for many hours straight without getting even cold feet, you're safe (have enough clothing and/or shelter).
To me, the first and foremost sign that I am loosing too much heat is when my extremeties become cold. This means my core temp is dropping, and my body is starting to react. So as SOON as the feet or hands get cold, I add up insulation. The same way around, as SOON as I start feeling too hot in the face/neck/ears area I know I'm overheating so I remove some insulation to avoid sweating.
Hypothermia is something we can easily prevent, given we react promptly to it's first warning signs. The more you let your body get far from it's ideal state (circa 37°C / 98.6°F), the harder it will be to get it back to normal. If you get down to 35°C, you'll most likely recover by yourself (still expect two full "I don't feel too good" days). If you get down to coma and 20°C core, it'll be hard and risky to bring you back.
Re reheating hypothermic people : it's a very complex thing. As a rule of thumb, as soon as the consciousness of the victim is altered (irrational behavior/coma), reheating really should be done under close medical supervision as the risks of cardiac fibrillation/arrest (already mentioned), gastric hemorragies, oedemas, hypo/hyperkaliemia, etc etc are numerous. This is serious stuff for serious professionals with serious gear (monitoring and defibrillator at the VERY least). The ideal setup being extra-corporal circulation (with external heating and cleaning up of the blood), warm ventilation (02) among other unpleasant things like gastric and intestinal reheating with warm fluids, etc.
Reheating should be done from the core towards the extremeties (core first), and as spontaneously as possible (if at all possible the victim should be placed in a neutral athmosphere and allowed to reheat herself on her own). Unless under medical supervision, reheating should be slow and controlled (1°C every hour or so). Unless the person is still able to move around on her own, an hypothermic VICTIM SHOULD BE MOVED AS LITTLE AS POSSIBLE, NEVER MOVING THE LIMBS TOO MUCH. This probably is the most important thing as you can move around cold and polluted blood and bring it to the core, which can cause fibrillation and/or cardiac arrest.
Prevention is a LOT better than cure, as usual.
Cheers,
David
