Ahem... I found out what I was doing wrong.
When it came time to put the blade back into the handle, what I did was push the female side of the screw assembly through the handle first and then placed the blade on this. I then fitted the handle over this on the other side and screwed it down. This was causeing the larger washer to come out of alignment with the bearing.
What you need to go is grease the blade hole. Then fit the bearing into this hole. Apply a little grease to both sides, place washers on top. Let the grease hold the washers in place. Make sure the washer is at the same level as the bearing. Apply a little grease to the visable side of the washer as well at this point.
At this point, you fit the blade slowly into the handle. It is important that nothing is where the pivot area is, no screws or the female part. Once the blade is fitted in and the washers have not moved at all. As long as you can see right through the hole and nothing is in the way, squeeze the handles together and see that the washers are still not out of alignment. If it looks ok and there is no visable difference in width on either side of the blade when pressure is applied, place the female into the handle. Look again and test. If all is ok put the screw in and tighten firmly. Once this is done tighten the back stop pin and back pin. The blade is equal on both sides now.
What I mean is if you hold the knife verticaly and look straight at the actual edge side and lock bar, the washers aught to be on either side of the blade an equal distance from blade and Ti handles. Before one side was slightly wider than the other. This also caused the lockbar to go over further. This EXTRA space caused by the bearing sitting on one of the washers rather than sitting IN the washer caused my problem.
I have seen the light, and it is good!
Gawaith is very happy, as am I.
Thanks for making me look again at this. Doing the assembly this way is the ONLY way to do it and keep the washers and bearing in the right place. Hope my dumbness helps someone out.
My Sebi is firm to open, but 100% better, the screws are now firmly tightened
WOO HOO! Cheers Walt and all.
Wayne.
"To strive to seek to find and not to yield"
Tennyson
Ranger motto
A few useful details on UK laws and some nice reviews!
http://members.aol.com/knivesuk/
Certified steel snob!
