Mine has only been running for a little over a week, 1600 is as far as I have pushed it so far but I know it will get hotter. The steel body is cold when it first comes up to this temp. but after an hour running at 1500-1600 it gets pretty warm, so the insulation is still soaking up heat at this point, which tells me that it is not maxed out.
You should only pull 80% of what your circuit is rated for.
I did not experience any unforeseen problems. The wiring was really pretty simple once I had all the parts in hand. The white (nuetral) lines I wired direct to all devices. All fuses, switches, and SSR switched loads are wired on the black (hot) lines. I used a switch and 1 amp fuse on the hot lead powering the PID, and a switch on the hot line going from the PID to the SSR, this way I can power up and program the PID without the element kicking on. Also a fuse to match the element rating, wired on the hot lead going to the load side of the SSR and subsequently to the element.
After a couple of firings I robbed the cooling fan out of our old microwave oven to cool the SSR and heat sink which were getting pretty warm. It runs very happily off the 110v leads powering the PID.
