I've honestly never felt a burr while free-hand sharpening, I believe it's due to an inconsistency of angle that the forming butt keeps getting knocked off, again, i'm using a 3 inch diamond stone as my primary sharpener, when I sharpen, I dont set the stone on a surface, instead I hold it in my hand and sharpen thereYou've hardly just begun!!! Personally, the becker took me quite a while to reprofile too.
Look at your second picture, you can see where you started to remove the black coating from reprofiling but it doesnt extend all the way down to the actual edge. Trust me, you've hardly removed any steel, you should see what I did to my leatherman
Are you feeling a burr along the tip and belly when you're sharpening?
This is how I mainly sharpen my blades, I do not own any knives longer than 4.2 inches so I never felt the need to get a larger stone, the diamond sits firmly and secure in my grip so it does not wobble when sharpening
https://flic.kr/p/ofUrh3
https://flic.kr/p/nYAH2XThis is how I mainly sharpen my blades, I do not own any knives longer than 4.2 inches so I never felt the need to get a larger stone, the diamond sits firmly and secure in my grip so it does not wobble when sharpening
[/URL][/IMG]![]()
"when I sharpen, I dont set the stone on a surface, instead I hold it in my hand and sharpen there "
This is the problem. Although you feel you are consistent in maintaining an angle, the bevels tell a different story. You should strive for a FLAT and CONSISTENT angle. The bevels are rounded and not completely consistent. Either secure the stone on a countertop or the knife. Holding it by hand almost guarantees less control and the resultant excessive rounding resulting in a convex edge with the edge of the edge less acute than desired.
I would suggest a bigger stone or plate placed in a stoneholder and secured on the countertop. This will improve your technique a great deal.
" except I use my finger to guide my angles." If you do this -even on a fine diamond or stone, you will abrade your finger if it touches the stone. This is a common mistake that we have all fallen for initially. Eventually you will have to rely on muscle memory or proprioception or you will have bleeding fingers.
Ken
^ You might want to chill a tiny bit. Let's all try to play nice. Ken is a really, really good guy, a great sharpener, and is very generous with trying to help others out in sharpening.
What I think he was trying to say is, if you drag your finger across a coarse stone as a height measurement, you'll eventually rub the skin off of your finger. I've done this myself when pressing on the edge of a blade and overlapping my finger tips onto a DMT Coarse stone. Murray Carter will caution you against the same thing. It's not unique advice from Ken.
I don't doubt your ability to sharpen a blade. Maybe you don't actually touch the stone with your finger? Or maybe your technique is just really light so you don't ever rub through your skin. Either way you might try listening to Ken. He's certainly one of the good guys.
Brian.
Psssh, what do you know about sharpening anyway?!I agree with the sentiment, no need to get up in arms over some competing advice. Besides, they're both completely wrong anyway - the only way to get really good at freehand sharpening is by tactile feedback! Everybody knows that... :devilish:
