Cool, thanks. The Alias II and 940 are good knives, but I'll go ahead and toss out some more for you to consider (all with metal handles).
For something a bit larger/heavier, you might also check out the 3.5" Hogue EX01 and Benchmade Presidio (3.42") or Mini Presidio (2.97"), all of which have 154CM blades and aluminum handles (the Hogue also comes in a G-10 handled version). There's also the Alias I, of course, which is just a bigger version of the Alias II.
For smaller/lighter knives, the Spyderco Sage 2 is an excellent titanium framelock with an S30V blade the same length as the Alias II's. IMHO, the ergos on the Sage 2 are a bit better thanks to its finger choil and "taller" handle, but the tradeoff is that you get a bit less cutting edge length and a wider knife when closed compared to the Alias II. Another possibility would be the Benchmade 707, which has a 2.95" blade made from 154CM and aluminum handles with G-10 inlays. The Benchmade 943 is the same as the 940 except with a clip point blade instead of a reverse tanto blade, and black aluminum handles instead of green ones.
For something small but decidedly not light, there's the Benchmade 755, which has a titanium framelock on one side and G-10 scale on the other. It's a real beast of a knife (in a good way!).
