- Apr 3, 2004
Like I said I got so much help last time I posted a topic like this I've got to try it again! (For those that are curious, we got her the Jester and it went over big! That little knife now opens all sorts of boxes envelopes and packets on a daily basis.)
This time we're thinking about Dad. This should be a little more fun because this is right up my alley and probably yours too.
I'm looking for a knife (obviously) that has some pretty specific criteria but I'm not sure what steel I should get for him. The problem is I know exactly what he likes, and I know that nothing I have researched quite satisfies his taste. I don't think anything will of course.
Price range here is around 100-150. This knife will be a heavy user and will spend a lot of time in jeans and dress pants.
Blade Length should be from 3.5" to 4.25", any thickness is okay. This needs to be a big(ger) knife, around the size of an Endura or slightly bigger.
Steel: Not sure. This knife will be often subjected to the horror of light prying. Yes I know. But I can't change Dad's habits. I was thinking S30V because I love S30V, but I wonder if D2 or 154CM might have more pry resistance? 440V? I dunno but I want to get him something with a good piece of steel
Any blade shape is okay, although a recurved blade or a drop point might be preferable.
Fit and finish - Conservative "typical knife" appearance. No bright colors. Satin finish blade. Plain edge. No serrations of any sort. ABSOLUTELY no coatings on the blade.
The knife should have a small unobtrusive clip as it will sometimes be clipped and sometimes not. The ability to alternate between tip up and tip down carry would be a great asset. He seems to prefer tip down however. A nice aftermarket belt sheath could be good too.
It'll need a lifetime warranty with available sharpening service.
It needs to be one handed operation. I don't think he likes holes for some reason so let's try to focus on thumb studs. I might be able to go with a hole if everything else is right though. The man gave me the sausage fingers that I have, so I know good and well if we do go with a hole he needs a slightly oversized one, and a Spyderhole would be best.
Handles... metal handles (especially aircraft aluminum or titanium) are fine. FRN would be a no-no, G10 would be okay I think (he wouldn't like the appearance but it offers a good nonslip grip). Not sure about any other materials.
Lock - Preferably Not a liner lock. Lockback or Axis Lock or Compression Lock would probably be the top 3 choices.
Brand - He likes Benchmade, but it doesn't have to be a Benchmade.
Finally it has to be a good old fashioned manual knife. Dad doesn't like assisted openers or Waves or anything like that.
This knife could see hard use way above and beyond any known tactical application. He works in the utility business and those people do ungodly things with knives that make me cringe, like hammer them into utility poles with sledge hammers. That's an extreme example but I'm not kidding. That's something his coworkers have actually done recently. Typically it might be used to cut through 4 inches of insulation on a piece of underground cable or pry a heavy duty staple out of a wooden reel. I know I know, but like I said I can't change him. It has got to be tough.
So far I've picked out the Benchmade 710 as a possible choice but it would have to be the model with the 154CM blade as it's the only one available in a Satin Finish. Another one I'm looking at is the Chinook II but I'm not sure he'd like the hole opening... any other ideas?
