Its possible that your not hitting the apex, have you tried the sharpie trick on the Elmax blade? I've actually found Elmax to be easier to sharpen then s30v and it also seems to take a finer edge. I would try spending some more time on the stones and make sure your actually hitting the apex before you do anymore stropping. Dont get discouraged I'm sure you'll get it sharp. Good luck![]()
Thanks, and yes I did the sharpie and I am hitting the apex. I did use the diamond spray on a strop and it is better but still not where the other steels are. I am starting to think the blade thickness behind the edge may be the culprit. It seems the primary bevel is at 30 deg or so and I did put a micro bevel on it at 40 deg. these angles are inclusive. The elmax knife has thicker blade stock than the s30v knives and I am thinking this is the reason it just doesn't glide through phone book paper. I can't whittle hair with it either.
