[youtube]TRt_aCz0mmc&feature=relmfu[/youtube]
Best advice I have is to listen to the sound the knife is making running down the stones. If it sounds slick, you're in. If it is grinding and skipping, you are making the knife dull.
Took me about 5 tries to get the technique down, now it's easy
If you are using proper technique you should NEVER be actively making the knife dull. At worst you would be "non-sharpening," but you should never actually be dulling the edge...
Thanks for the tip! I just tried your listening technique on a quick touch up and it worked like a charm! This is some of the best advice I've read about the sharpmaker so far.
I am testament to this. LolIf you are using proper technique you should NEVER be actively making the knife dull. At worst you would be "non-sharpening," but you should never actually be dulling the edge...
Here's my technique with the sharp maker. I still use it to this day, and many hundreds of people have told me that my method works excellent for them.
[video=youtube;-MHe_8wTHmg]http://www.youtube.com/watch?v=-MHe_8wTHmg[/video]
If you overextend the angle, the edge is then rubbing across the stone more perpendicular.
Good to hear. I love the sharpmaker, fits most of my needs, even in the field sometimes.
The Sharpmaker is great for maintaining edges, but the grits are too fine for sharpening a really dull knife in a reasonable amount of time, or for changing edge angles.
Exactly, that's not using the system properly.
I was trying to discuss how you could dull edge with improper technique. . Maybe I was unclear. Thanks.but you should never actually be dulling the edge...
The Sharpmaker is great for maintaining edges, but the grits are too fine for sharpening a really dull knife in a reasonable amount of time, or for changing edge angles. I tried the diamond rods and wasn't very impressed, ended up getting an Edge Pro. Years later, for serious edge re-work, I use the Edge Pro or my stationary belt sander, but the final edge is always on my Sharpmaker. When I've already used on of the "fast material removal" sharpeners, the Sharpmaker is all that gets used.![]()
