Hi,
if used for cutting bloody, humid things or even kitchen duty around meat and fruits... it is much more easy to clean a naked skeletton knife under the tap, and then dry it.
Naked would mean then that it would be much more hygienic.
I've been looking at a lot of pattern of wrapped handles and they are all very beautiful and fancy but soon they will be turned into a humid germ nest. (Unless there is product to keep the moisture out of the paracord, and a a wrapped pattern easy to clean without a brush...)
Also the short blade of the Izula makes the handle in contact with the cut material more easily. I mean the longer the blade the safer the handle from getting dirty.
Really, a naked Izula would not only be sexy, but also for food prep it would be much safer in regard of simple hygien.
What do you think ? (It was one of the main concern in the design of Fallkniven WM1. and knife with kraton handle less confortable and less ergonomic than the Izula.)
It depends of the use of the knife. A chopper would be used for wood and "dry works" but a small workhorse like the Izula will be used for a lot of different chores, dry and wet...
Should paracord handles be kept for "dry chores"?
Cheers
Nemo
