David Nowlin
- Jan 17, 2018
Not bone dry but not dripping either.
That's what I installed on my older model Ranger Pro that did not come with a stud.View attachment 2015365
Okay one of these? Is it just better than the one the knife comes with?
Yeah watch your thumb. Oiling might delay the break in on friction parts.Okay got it oiled and working on breaking it in.
It seems that the worse resistance is as you apply pressure to the thumb stud it opens an 1/8 -1/4 inch then binds. Which if you’re not careful you can slip your thumb into the gap and the possibility of your thumb being sliced is increased.
I have to wonder if that’s a design choice?View attachment 2015468
The Sports pro has a longer flat spot with a sharp transition to the rounded part so as i open it there is heavy resistance then as i force it over that transition to the rounded part where it has much less resistance abruptly.
My 110 transition area is shorter and hardly any resistance. No notchy feeling on the brass example.
Sorry it’s hard to capture what i’m talking about but you can sure feel the difference.
i made the mistake of leaving this one in a leather sheath too long. I see i missed a little of the green stuff when i cleaned and polished it.
Can’t really see it with a naked eye.
I am talking about the black stuff (CeraKote) not Verdigrris. One of the slowest 110 format knives that I ever had was a Model 560 “Ninja” Titan that had a black painted blade and black painted scales.
Ahh ok on the paint tiguy7
Bastler you did this on this sports pro model like mine? If so how easy is it to take apart?
To update you, i did some filing and then used a dremill tool on a 112 i use that has this same issue though not as notchy as my new sports pro and as a test it seems it will solve the problem. Only thing is it roughs up the inside of the brass bolster a little bit ( not too noticeable to my eyes) so i would need to take the blade out of the aluminum 110.
