Well, a year has gone by, sorry for the delay folks!
After having put this knife in a box and set aside, it got burried and moved and just plain ol' forgot about. But I dug it out today and did a little work on it! I picked up where I left off, pinning the scales.
So, after the final fitment of the scales, I drilled the pin holes for attaching the scales. When I pin them, I take my rod stock and clamp it in my bench vise, pein over on end and get it flush. It is the inserted through the linr side and fitted flush. I can now snip the pin to length with zero waste. I used a tapered reamer on the stag and peined it down by hand. It is about 95% finished on th head, I will round and polish the pins when I get the scales shaped a bit further.
Once the scales were pinned, I ground them down to the liners. I tapered the ends of the scales to meet up to the bolsters. This stag has good figure, but was pretty tall at the ends, so it will look a little funky.
Once I was satisfied with the preliminary fit of the scales, it was time for a test fit and assembly. I got the middle hole drilled after pinning the scales, and taper reamed. During the test fit I notice that the spring and blade don't meet up perfectly. I don't think I will try to remedy this, if the original knife didn't fit perfect, then why should it now! Although I am very tempted to do something to clean it up, when closed, the spring sits nice and flush.
Also, the blade centers well, even though things aren't fully tight and closed up yet. But, I ont know if its from being run over or if it was just ground funky, but the blade has a slight warp to it. It appears to be ground off just a bit.
So, all in all this is shaping up to be a nice little knife! Here is your first prevue of what it will be...
This One Trick Pony is now back on top of my to-do list. Its not getting burried again unless its in my pocket! The end is in sight! I will get some more work done on it tomorrow as well. Of course, pics to follow.
Cheers!
-Xander
