i need a folding knife for edc at work
I work on a farm, and all the abuse and wear that entails. But I am also constantly cutting fruits and veggies for me and customers to eat. I need a decent slicer, but also strength in the tip and the lock. I like benchmades and spyderco's. I curl recently use a 950 rift and a spyderco military. Any suggestions?
The spyderco balde is primarily designed as a slicer, it's going to slice better than a lot of kitchen knives will. Only suggestion I can think of in that setting would be a a mora craft line or a hultafors craftsman. Both are tough and will slice until your hand gets tired of slicing. I use a Hultafors and mora for similar duties and they both do great. The mora will be used more because it's stainless and the only other thing I ever cut with it is final wood prep if I don't have tinder around me available so it's always clean.
The mora and Hultafors are so affordable you can add one to whatever you order and use it during them high demand times when the knife is continuously out and cutting.
I know you said folder, but you might like the Esse 3 fixed blade as well. No lock better than a fixed blade, and has the you break it in any way and we'll give you a new one warranty. tough to beat. and not much bigger than a large folder.
An Emerson CQC-8 might be another good suggestion for you. That thing is def a slicer with a good tip.
Honestly the Rift is pretty darn good for what you're doing, I use mine all the time for every task I can find, it seems to be a do-it-all design.
How about a Cold Steel American Lawman, Recon 1, or Ultimate Hunter. Spyderco Manix 2, Military, Paramilitary 2. Kershaw ZT 770. There are many but hope you enjoy what you pick. I also like the Benchmade 940. Good Luck. Kevin
Have you thought about carrying a fixed blade? There are some great choices out there.
I already suggested that in the blast three he posted about this. I'm guessing that's why he said folder.
It's a farm, concealment shouldn't be necessary.
I saw that after I posted, my bad... Yeah, if I had a job where a fixed blade was appropriate, I'd be carrying one for sure.
Flat ground Spydercos slice very well, but their tips aren't terribly strong (however, they're strong enough for most uses). Military, Paramilitary 2, Manix 2, Ffg Endura, are all good solid knives.
Benchmade has the 550 Griptilian (with a nice utilitarian blade and strong tip), the Onslaught is a favourite of mine as well. Honestly, I don't think either will outperform the Rift.
If you're willing to give traditional knives a try, Opinels and Douk Douks might work for you. They have thin blades that slice very well, can actually take quite a bit of rough use and, if they do break, are cheap to replace. A Case Sodbuster, Trapper or Large Stockman (the last two have several blades, so you can keep one for food use). I used GEC trappers at my ranch a lot, lovely, strong knives.
Why don't you give CS Finn Wolf a chance? It's not a premium steel, but slicing, tip strength, and solid lockup requirements are satisfied. If you loose it somewhere on the farm you wouldn't worry too much considering the price.
If you want a premium on that, go for Ultimate Hunter with CTS-XHP.
I got a small farm as well. I do like the CS hold out 1 fully serated. But I cut a lot of ropes. and hoses and such. Goats=hard work. Its my first pick for working the pasture. aggresive serrations.
Farid K2? The steel will hold a Great edge, even if you encounter some dirt while picking some veg with it, and it is a Slicey beast, pretty to look at too (especially if you have it ano'd).
I suggest you carry two knives; one of the larger Spydercos would be a good choice for slicing and general cutting, and then something tougher and less pointy for harder use.
As the son of farmers (and thus a part-time farmer for most of my life), here's a bit of what I've learned so far:
Stay away from uncoated high carbon steel. I have had issues with CPM-M4 and ZDP-189 rusting and staining, and in the case of ZDP-189, pitting, due to the high acid content in certain products such as tomatoes and tomato plants.
If you're not using your knife as a substitute for another tool, then a full flat ground or high flat ground blade is the way to go, every time. I've found that farm work more often than not requires smooth, clean cuts, and a thicker blade will not make a clean cut through a thick piece of material.
If you use a locking folder, pick something with a lock that is easy (and safe) to disengage one-handed. Backlocks are a huge pain in the butt in this regard, especially as I find it diffficult to disengage them without my thumb or forefinger in the path of the closing blade. I also avoid opinels and many traditional knives thanks to the number of times I've cut myself trying to open or close them. Farming often involves sweaty hands, gloves, or a poor grip- better to find a knife that minimizes your chances of cutting yourself.
Finally, two knives might be the best solution- something more robust for farm work, and something with a thin blade stock for cutting fruits and vegetables.
To wrap up this somewhat rambling post, I can personally recommend two knives to you; the Spyderco drop point UK Penknife and the Benchmade Doug Ritter Griptilian. The UK Penknife features a slim and slicey blade made of CTS-BD1, which resists corrosion quite well, takes a decent enough edge, and can be easily touched up or resharpened. While it does not use a locking mechanism, its choil prevents it from closing on one's hand, and the lack of a lock makes it easy and safe to close. It is also supremely ergonomic and is an absolute wonder in terms of grip. I should also mention it's very easy to clean thanks to the lack of washers and entirely FRN handles- I just hit it with a hose, then shook out the excess water. No rust so far. As for downsides, it's a relatively thin blade, and it'll need fairly frequent touch-ups if it's being used to cut abrasive material.
The Doug Ritter Griptilian is supremely robust, utilizes (IMO) one of the most safe and user-friendly locks on the market, as well as an excellent grip, and a very tough blade. Its high flat grind makes it a reasonable slicer- not as great as the UK Penknife or an opinel/traditional design, but acceptable nonetheless. It's easy to open and close, and S30v/M390 are both great steels with excellent corrosion resistance.
spyderco military is a great option, slices like a demon, and is tough as nails to boot. The tip is the only delicate part.
