- Dec 7, 2019
Not sure if this is enough blade length for you, but perhaps a Becker BK2?
... I tend to beat the snot out of my knives, in construction, the feild, and my shop. ....
... I have had bad luck with Cold Steel and edge retention. .... I had to spend a lot of time sharpening it. Not cool.
Unless it is an integral design (such as the Drop Forged knife from Cold Steel mentioned above) with a differential heath treat to keep the pommel soft (otherwise it might shatter on impact) you are looking for a full tang knife and welded (not soldered) pommel with a flat wide end (otherwise it will be useless for hammering stuff). If both pieces are made o the same steel, differential heat treat is required, if they are made of different metals, depending on the weldability of the joint, you might experience fatigue cracks in the HAZ and premature breaking.... I really need a heavier pommel that is well fixed(I have knocked them off.
Then how about the KA-BAR big brother? 9 1/2 inch blade.I have two of their Machetes, good stuff. But this one's not really the size I am looking for.
After stating that you, basically, use your knife as a do-all-demolition tool... you complain about lack of edge retention... Edge retention and toughnes (which seems to be required for your uses) do not go together well. Some steels offer a good compromise of edge retention VS toughnes... but always talking about knife chores.
