Ok I've been a structural FF in an urban dept for 27 years 100's upon 100's fires . First there are is no folder that one can open and close easily with FF gloves on . Take a thick pair of leather gloves get them soaked , toss them over the pipes coming mg off the boiler to,dry, replete a few dozen times till they wear out and you need new ones .
It's hard enough to,properly grip an ax handle let alone a knife . These gloves are not like your leather work gloves way thicker.
If you,have to,go folder get one with a large handle and flipper , tie a loop of para cord on it and clip,that to,your bunker coat or scba and practice with your gloves on .
Kydex holds up just fine. Remember our helmets are plastic and face piece is rubber.....
You should consider a fixed blade in kydex sheath hanging from your gear as well, that's really the best way to,go for you .
Chris "Anagarika";16878665 said:If there's no blade length restrictions, a Vold Steel Voyager will work. The lock operates like a lockbank & the blade is heavy enough not requiring manual opening. A flick will inertia open it. My sample of XL Tanto does.
Other than that, a well worn Pacific Salt definitely is smooth enough to be wrist flicked. No rust, zero maintenance.
:thumbup:
Good luck!
Never used it on a structure fire, but for rescue and wildland, spyderco assist. I have the salt version without a cobra hood, but the spydie hole is sharp enough to catch on my gloves.
Sent from my SM-N910V using Tapatalk
I also use the Assist, it works good with the kevlar/leather gloves I use at work. Not just because of the spyderhole and cobra hood, but also for the size of the handle. I tried with the Endura, but the handle is so slim that the gloves are hindering the blade when I'm trying to open it with my thumb.
I have the orange vg10-version.
Edit: the rounded tip on the Assist is also a must for me on a rescue knife..
