- Aug 2, 2010
Hey guys, I know this topic has been discussed multiple times in the past, but I have been searching for a while trying to get a clear explanation on how it's done and can really find any. I have used the bladeforums google search engine and read a number of threads as well as just plain google searched and read some more, however none of them quite helped me with the questions that Iam having.
What I am doing is re-handling an older, fairly cheap kitchen knife that has some sintimental value and the gentleman just plain likes using it
It's one of those typical kitchen knives with the cheap wooden handle falling apart and the cutler rivets comming loose etc. (but it's made in Japan
So I'm not doing anything fancy, but he does want the handle to be a bit longer, so I'm making the handle cover the tang by doing a "frame" handle type deal but using a piece of G10 the same thickness on the tang as the "frame" so I can have the handle extend just a little further back. It's a pretty slim blade and handle (tang)..
--------------------------------------------Actual Questions Below-----------------------------------
Ok, so anyway, I really don't want to just rely on epoxy (g flex) to keep the handle on and I already have the ironwood scales and G10 "frame" shaped and drilled for three 1/8" inch stainless steel pins.
So my question is how do I go about peening the pins without doming them? Can they be more upset instead of just spreading a very small portion of the very top?
I have read some guys epoxy the handle using temp pins, then take them out, shape the handle 90%-ish, then slightly countersink the pin holes and peen until the countersunk portion is "filled" with the pin material.
The thing is, this 1/8" is pretty hard material to peen, I've practiced on to scrap wood and was able to dome them, but that's not what I wan't.
I was wondering if if I can just slightly taper the holes in the wood on each side using someing like a small rounch tapered needle file (since I don't have any tapered reamers) so that it forms an hourglass type shape, and then do more of an upsetting of the pins so they are more wedged in there as opposed to a dome, which is the way I believe bolsters are held on.. (never done bolsters either)
Also if the above technique of upsetting won't work, how do I know what diameter to courtersink the holes with and how deep to go, and how much of the pin head to expose. I obviously don't want the pins to look way out of round and I don't want them to crack etc... I would probably be using a larger diameter drill bit to contersint since I don't have a proper one, though I do have a number of different sets of stepped bits.
Anyway, I would really appreciate any and all help regarding this as I plan on doin this on all of my knives in the future, so I can have a mechanical fastener. And I don't like corby bolts since I like using smaller diameter pins on even my larger, thicker handled knives and the 1/8" corbys have threads that are very short, pluss they are $$ and I just don't wanna mees with them lol. But that's besides the point, I really want to learn how to do this with SS pinstock so I can make my all my future handles look as If I just epoxied in the pins and ground them flush, but I wan;t the added benefit on the mechanical fastener.. Is this realistic, or should I plan on gettin some 1/8" nickel silver pinstock since it's easier to "squish" or something
*Note - I am aware that peening stuff like micarta & G10 is more forgiving than natural materials such as wood & ivory etc. So I'm not sure if this means I should only use a certain method of peening with wood that would make it less prone to splitting over time, or even during the peening process, but still be able to use a number of methods using man made materials...
Thanks for any and all help once again fellas
:thumbup:
~Paul
My YT Channel Lsubslimed
~Paul
