I've been playing around with the high temper for ATS34/154CM and so far I'm getting more consistent results.
I pre-heat in a 24" Paragon at 1500 deg F for 10 min.
Ramp to 1950 deg F, hold for 40 minutes.
Quench between 2" Aluminum plates while blowing forced air between.
here is the problem....
It takes about 45 minutes for the Paragon to cool down to a little below 1000 deg F. I don't want to wait that long before tempering. So I'm wondering what's going to happen when I temper at 400 deg F for 2 hours, and then use the 1000 deg F for the other 2 hours.
As I understand it, using Crucibles heat treating specs.... you gain that extra Rockwell point by using the 1950 hardening and then 1000 deg temper.
Also let me say that I am not using any Cryo; not that I am against it.....Although I do have my reservations....It's just not in my budget at the moment.
Will the steel take on a new structure by using the low temp on the first temper? Something that will be totally ruined if I bump it up to 1000 on the second?
I know the disadvantages of using the high temper. Lower corrosion resistance, lower toughness, etc. These are paring knives that I'm making by the way.
I've noticed that some peoples numbers are all over the board in the stainless arena. I'm having fits with it. My 440C hardens up great, sharpens great, tough as nails, holds a great edge too. Even with it there are hundreds of degree's difference in some peoples hardening and tempering recipes. It was a total crap shoot when I first started working with it. Some say temper for
1 hour at 300 deg F 2 times, others say temper at 400 deg F 2 hours 2 times.
Some say hold it at hardening temperature for 10 minutes, some say 30 minutes, some say an hour. See what I mean? And that for 440C!
I've searched, read, experimented, made some nice looking knives that don't hold an edge for nothing(not too many). I've blamed it on my foil, switched to the no carb dip stuff for high heat. The stainless just isn't impressing me like W2, 1084, 01 and the other Carbon steels did. Heat treating is the fun part for me.
Anyway, now that I'm all worked up, and everybody knows how I really feel, it's late and I need to go back out to the shop and get those blades out of the 400 deg F oven and dream about what I should do next.
If anybody has any words of wisdom, I'm all ears.
thanks
Chris
thanks
Chris
