It's used to attach the steel lockbar insert, so the lock is steel-on-steel instead of titanium-on-steel. It helps alleviate the initial sticky lock symptom that sometimes comes with titanium lockbars. It also doubles as an overtravel stop instead of having the lockbar stabilizer disc being separate. And in the off chance that the lock face on the lockbar wears down too much, the lockbar insert can be swapped out (instead of swapping the entire scale).
Thanks for the explanation.
Hm. Well, I have one of the older models. Not sure if its worth selling to get a newer version for that feature....
Not worth it at all. IMO
Doesn't mKe any difference, they are discontinued so, if you like it, keep it. The likelihood of seeing any new ones rolling off the assembly line are about the same as new folks reading the exchange rules before posting, zero!
I must be late to the party because I havent checked up on updates to the ZT301. But can anyone tell me the purpose behind putting a screw onto the lockbar?
The only reason I can see is that if you bend a lockbar outwards or somehow push too hard outwards on it while attempting to close the knife (without that screw/some sort of stop in place), it would permanently damage the mechanism. It would be too much torque for the pivot point which doubles as the spring (the thinnest part), and this would cause the metal to deform or break. Let's be honest here, a child could break a 3 inch x 1/2 inch x 1/16 inch piece of steel with their hands.
But in the real world, this should never happen unless you try to break the knife on purpose. The screw prevents that from happening, so there is no chance of overextending the bar at all anymore. It solves the inherent design flaw described above.
That is just my take on why the screw is there. It isn't there for aesthetics I don't think, and it doesn't affect any other mechanism. I don't think it is for a replaceable lock bar, since I searched pictures of the knife and the lockbar was still connected in one piece with the frame.
You are confused. All but the last versions of the 301 had a lock bar stabilizer (look it up). The last version does not have a lock bar stabilizer but rather a lock bar insert were the lock bar interfaces with the tang of the knife. This insert has a screw and is removable.
I searched zt 301, everything that came up had the scred at abiut mid-bar height
Any links to the new model?
This is a very well known thing....
They've done it on a bunch of models.
Ahh, I see. I didn't know about it, since I don't focus much on production brands, but thanks for the heads up.
That is news to me, wow farewell 301!
