- Mar 4, 2014
Melt some floor wax into the blade slot to seal the wood and keep it from swelling and binding the blade.
On darkening your slip sheath. Warm pure neatsfoot oil (not the compound). I use a dedicated crockpot but I do this a lot. Ya could use a little jar in a pot of water on the stove. Ya want your oil warm but not hot. Brush on a light even coat. Be careful it is very easy to over do and your slip will be soggy, just a light coat. Then set it out in the sun for a bit. The uv rays will darken the leather. Remember to flip your slip over so that each side gets an equal amount of sun.
After oiling, the slip might be a little mottled in color. This is normal and the color will even out over time, this is referred to as the oil setting. Did I mention use a light coat? I would not use Sno Seal for what you are trying to accomplish with your slip.
Oil it up as described and it'll get softer and darker and you will love the patina life will give it.
I love my opinel, the only knife I have that cuts better is my Northfields #73 in cocobolo. The ring lock is also such a neat mechanism too.
Idk if anyone else has said it, but avoid getting it wet. The wood can swell and make opening the knife impossible.
After reading these I wondered if it would be a good idea to add whatever wax/conditioner/cream to the wood also. If absorbed, would it prematurely swell the wood, or just protect it from future water exposure? I've never carried an Opinel for more than a day or two at a time. But have always been intrigued by them.
Some day I would like to try whittling on an Opinel handle. Maybe with this year's Traditional Forum Knife. But I would probably need a "paint-by-numbers" format for beginning whittlers.
