The lesson is that it takes a loooong time to restore a badly worn edge using a ceramic hone. With a hard tool steel like M2 it will seem like forever. By the way, did you put your final edge on using only the 20-degree settings? If you did your cutting performance on stiffer material like cardboard may be significantly reduced from the factory edge. You may want to do some back beveling at 15-degrees. That will take forever.
