I shaved my butt...
off my BK2 and cut out the center of the handle to lighten the load. Then some jimping and then a stripping. My goal was to make it more head heavy for chopping.
Let the cutting begin. Dremel chop saw blades in my drill.
This represents about 45 minutes of grinding.
Here is the center.
Before I start with the files.
Some of my files. Used all on the center.
Time to make a spacer so I can still torque down on the
center hardware to make the handle secure. This a Nylon.
Shaved/filed it down to 1/4". Drilled the hole larger.
Wow. 3+ hours later and I've taken a whopping .6 ounces off
the knife. Not good enough.
Time to cut the Butt off. Since I have compromised the strength
of the knife by removing a large chunk of handle, I certainly will not be
pounding on the butt like Ethan did on his burn barrel. So, may as well
make it go away.
Home made grinder with 72" belt. I took my time and did not heat up
the steel very much. Also, it is only 9 degrees in the garage. That helps keep things cool.
Know when to say "when". You can always take more off, but can't ever
add it back. Time to hit it with some files.
Again, another hour of filing and then some sanding and I have a nice
satin finished butt that follows the contours of the Grivory.
Time for some jimping. I do this with the black coating on so the file has
something to bite into and get going straight to guide it into the steel. Plus, if you do slip, and are going slowly, the coating will take the hit, not the steel.
Seeing as I now have a bunch of exposed steel. I may as well strip the whole
thing. First, lay down a layer of citristrip gel.
Lay the knife in it and lay more on top of the knife.
Three hours later. Gently scrape off the coating. This one did not bubble up
like the last one. But, then again, it had 9 less hours so soak.
Just about done.
Lovin' that "Stone Washed" finish.
After a nice rubbing with the Scotch Bright cloth. The handles go back on.
I must admit, that is an exact match. OCD will do that to you.
Ahhh.
Jimping.
Darn near knocked an ounce off the knife. Now it does have a blade heavy feel and acts like it wants to chop a little more. So I guess mission is accomplished.
Thank you Ethan for such a fun knife design to play with and for condoning the experimentation with your knives.
That is cool bro! :thumbup:
Now I'm thinking I need to go out and get some more tools. :D
Excellent job. You are enough of a perfectionist to do top quality work.
I think you'll find that you get less "felt" vibration when you chop with it. I'd like to hear if that's the case. Did you make the 2x72? If so, I'd love to see your plans on it.
great job on the deuce
randy
Damn, man, you are a freakin artist with those tools! The jimping is awesome, looks machine precise, but it's even better since it's been done by hand. Really, really cool.
i think you voided your warranty dude :)
now, is a paracord wrap lighter than the handles? more chopping?
i'm wondering if an accessory handle bolt on to add 6-9 inches, possibly with a curve to fake a Machax ;) would make an interesting chopper...
Tag, I swear you're like my new hero:D
not just for your craftsmanship but more so In hope you'll send me your design/specs for you homemade madness (grinder)... VERY NICE !!
wow:eek:
I'll get back to this thread in a few minutes. I'm still in shock.
Moose
If I had those tool in my garage, I'd get your kind of ocd in a second.
You got some skillz though.....and dedication. Would take more than a sec to get those....
please do a how to on the jimping, that is freaking sweet!
+1
Excellent work and detail, great picks too. I'm glad I'm not the only one with OCD ...
Beckerhead #76
That is some truly great work, Tom. I mean really great. Pics are awesome too. I'm a modder from way back, but I have never tried anything like that. That jimping looks phenomenal. Not sure I would want the knife blade heavy, but you did and done a marvelous job of doing it the right way.
Great stuff, really, really great stuff.
Moose
Hey Tom Gannon......
My, my ain't that some pretty work.......A mod with a purpose.....When it warms up a bit I really want to know your impression of how it changes the"chop".......Loverly work there Mr. Tom......
All Best....
ethan
Tom you are a talented man! Thank you for all the how to threads.
I've always preferred the older BK2 without the tang extension and believe the knife looks better without said extension. Nice work.
Vin
Pretty cool stuff there. Nice to have the tools, workshop AND know-how. Been thinking about turning my BK-2 into a clip-point. I don't care anything about turning such a short knife into a chopper (that's what the 9 is for ;) but some other mods are definitely being considered. Cool nonetheless.
