I survived, detailed log of my entry for the survival contest
I posted this on the contest thread, but I thought I'd post it here as well to received extra feedback from people.
I had a BLAST
Woohoo! Well, I'm alive, that's a good thing. I was able to get out last night and I had a great time. I wish I would have taken more pictures, but I'll post what I've got.
I took a little notebook to keep track of some thoughts and what I spent my time on.
I decided to "force" myself into staying the entire night by having my wife drop me off at the beginning of my hike, and not coming back to get me. So, basically when I was done, I'd have to walk home. I figured this would make it more realistic in that if I was stranded out in the woods, I would be just a 20 minute walk from my car. So, from my camping spot to my house was about 3 miles, which would have been a PAIN in the wee hours of the morning. I wanted to make sure I stayed the whole night! However, being 1 month out from 2 surgeries, I didn't want to get hurt and be stuck, so I did take my cell phone, which I normally would anyways. I liked the physical condition of my body, in that I'm still a month or two away from having my full strength and stamina back, so I thought this would add to the "survival" situation, as if I was hurt, or had minimal energy to exert. This helped me think more critically of my gear and my choices that I made. I'll explain more as I go through the night below.
Thursday - Perfect weather, no clouds, very little wind, no rain at all, but everything was VERY wet from rain from the previous days.
3:30pm. 45F. My wife dropped me off, this was her best concerned face! She was a little nervous, as we are somewhat unfamiliar with the place I was going, this was my first time camping by myself anywhere, and she was concerned my body might not be up to it physically. She loves me, so she let me go!
It was about a 20-30 hike to my spot, I had been to this area before, but not to this exact spot. I just walked until I found a nice place.
4:00pm. Started setting up camp.
Took me 30 minutes to get my tarp setup, a small reflector fire-ring setup, and a few other things setup. This was my second time using this tarp, and I'm not sure how much I like it yet. It's light, but it took up a lot of space in my pack. This is one of the items that I wouldn't normally take with me on a hike, but I took as a little extra protection from the elements. However, once I was out, I depended primarily on my space blanket, trash bags, fire, and clothing for protection and warmth. I was laying next to the fire most of the night and not under this tarp. If it would had been windy or raining, I would have been under it for sure though. A nice poncho/tarp might be a good alternative. The tarp did keep a lot of moister off my gear.
My fire pit worked great. I made it on a small slope, and setup some tall rocks in the back to try to reflect some heat towards my shelter. I think it was too far away from the tarp however to notice any heat being reflected into it. Having one high wall helped out a lot. Once my fire was going, I was able to prop wet ground wood up over the fire to dry out. This was especially great since just about everything was wet from a few days of rain. I also made the fire pit longer than normal, so when laying next to it, it would heat my body better.
4:30pm. I started gathering firewood. I had about 30 minutes of actual light left, so I was scrambling. This is where I started using my kit. I wanted to rely only on the mini-flashlight from County Comm as my light source. I EDC a Nitecore D10 (which is amazing), but I decided not to use it. This little light worked fine, and I managed not to lose it. Though I did drop it in my fire once! This is one item that I definitely wanted to upgrade, but it did work well. I held it in my mouth most of the time, which worked ok. Some thoughts on upgrading below.
I found a great firewood score, and though it wasn't very far from my camp (maybe 100 yards), it was very difficult for me to drag it back. Basically some huge branches had broken out of a tree, but that were still stuck in the tree. I started break some branches off, but decided I wanted the whole thing. This probably wasn't a good idea. It was getting pretty dark, and I wanted fire! The heaviest part of the branch was about 15 feet high, stuck on another branch, leaning against the tree. I started to pull on it to try to shake it loose, only to release a branch that was under tension, which came and knocked me in the face, popping a lens out of my glasses, and scratch my face a little. I luckily found the lens, it was fine, and it popped back in place just fine. An eye wound not have been good. I still wanted the wood, so I tried to carefully pull it down. I managed to get it out, but I needed to take all the branches off before I could move it. Most just broke off, while the larger ones wouldn't budge. This branch was 8”+ in diameter. I got my pocket chainsaw (which I do often carry with me on hikes since its so small) and tried to section it up. But I just didn't have the energy to do this. I couldn't saw very hard for very long at all. Eventually out of frustration I just dragged the whole thing back to camp, getting poked along the way as the branch shifted around. Once back I decided to persevere and at least cut it in half. This took me about 10-15 minutes to do, working in little shifts. After this, I decided to burn it into sections over the fire, which worked perfectly and forced me to conserve my wood usage.
Once I gather enough wood to get a good fire started, I took some semi-dry branches and split them with my new Breeden Blackwood (5.5” blade). I then used them as a fire floor. This worked great, and I use this technique at home too. I don't think I would have been able to do this with my SAK Farmer, which is my kit knife. Maybe some smaller branches, but I was using some 3-4” branches. This wasn't absolutely necessary, but helped quite a bit.
I used a PJCB from my PSK, my firesteel from my PSK, and my Farmer to start the fire. I had made some dry wood shavings to use as secondary tinder with the Farmer, it made nice thin, wide curls. I then piled on some small twigs (you can see how much moss there is here, which keeps things pretty wet), which I had pilled up earlier. Unfortunately they were already damp from being on the grass, so it took a while for them to start burning. But soon I had raging inferno!
I continued to gather some more wood, hoping that I had enough to last the night I went to rest under my tarp for about an hour, I was exhausted.
I'm not sure if it was the pocket chainsaws fault or not, but man I was hating that thing. The wood was very hard, and really pretty thick, more on this below.
6:00pm. Even though I hadn't really done much, it felt great to just lay down. I nodded on and off for about an hour, and decided that if I was going to gather more wood, then I should do it early on. The “if you think you have enough, get three times as much” saying echo'd in my head. So I went back to the same tree and got another branch that was a little thicker, but shorter. Dragging this one back wasn't any fun either. There was no way I was going to try to saw it in half, I just layed it over the fire to burn in half.
7:30pm. I was starting to get a little cold, so I decided to break out my space blanket. I have several of these, but I'd never needed to use one before, so I had never opened one before. Man do they ever fold down small! This was my favorite piece of gear. It did a good job of keeping my body heat in while in my shelter, it kept my dry from the wet ground, and when next to the fire, it reflected more than enough heat. I was just amazing at the difference this thing made when huddled by the fire. It's like when someone first gets glasses, and they keep putting them on and off, amazing at the difference. I kept putting it up and down feeling the difference that it made. I guarantee I'll always have one of these with me. I'm very glad I decided to get a slightly larger kit box, so that I would have room for one!!!
Throughout the rest of the night, I kept using small rocks that I set next to the fire to keep my hands warm (I was wearing leather gloves the whole time, except when I was trying to sleep). My gloves got cold quick, and carrying around a small hot rock was great to keep them warm when making a side trip, or just sitting around.
8:30pm. I had made it a few hours, and I was starting to get bored. It was also a little eery, being in a new place by myself at night. I haven't had enough time in the woods at night yet to that comfortable with it, several times I swear I heard some tree zombies. :D One thing that helped me pass the time was to set time goals. I brought a package of ramen noodles, a can of tuna, and some homemade hot chocolate mix. I was craving this very early on, not because I was hungry, but because I was anxious to have something to do. But I set a time goal of 9:30pm before I could crack everything open. This allowed me to continue some much needed rest, and to progress through the night. I continued to do this throughout the night in my trying-to-sleep/tending-the-fire pattern. I'd make myself try to sleep for at least 1.5 hours before I'd get up to tend to the fire. I'd sleep for about 30 minutes on the middle, and I had to wait before I could move on to the next “thing”.
10:00pm. Decide to make some food! I used my metal cup to do all of this, and it worked fine just to set them on some hot coals. Doing this didn't get anything to a rolling boil though, but enough to sterilize water. I also had some water purification tablets in case this didn't work out well. Thankfully, I didn't have to use them. I was going to use some of the wire in my kit to have it hang over the fire, but this was easier, and worked just as well. I really needed a lid, so I'm going to add some aluminum foil. This would also work well to boil water, although the cup is multitudes easier. I usually have my cup and a nalgene with me, so I didn't think using my cup was a stretch.
1:00am. Having waited an hour an a half, and my feet being quite cold, I decided to get up and warm up. After feeding the fire, I decided to whittle with my Farmer for a while. I'm not much a whittler, though I'd like to be. I usually get frustrated quickly since I can't make anything. But, I told myself I'd whittle for at least 30 minutes. I spent some time making fuzz sticks, some with tiny thin curls, and others with thin wide curls. I spent a lot of time just slimming down one piece of wood, until I decided to make it into a mini-sword for my son. It didn't turn out awesome at all, but he likes it! This ended up keeping me bust for well over an hour.
Overall, I slept maybe 4 hours, which is pretty good considering the situation. I normally don't sleep much in the woods though.
5:00am. 26F. I kept hoping that the sun would rise... but it didn't for another 2.5 hours! At this time, my feet were COLD. I fed the fire with my shrinking pile of wood, and I stood very close to it to try to warm up my feet. I was pretty tired, and kind of in a “want-to-sleep-more-trance” when I realized I was probably a little to close to the fire! Yup, my pants had melted! I just happened to look down and noticed some slight smoke coming from them. I was very frustrated with myself for letting this happen. This pants were awesome! I decided to take my shoes off and warm my feet safely, while letting my socks dry out and warm up. I'm not sure how much longer I needed it would have been for my pants to ignite, but I think I was pretty close. I was wearing all synthetic clothing, which just melts and burns pretty fast. That mixed with my hairy legs would not have been fun.
I spent a long time laying next to the fire on top of my trash bag and space blanket. I tucked just a little of the blanket under me, and used the rest to reflect heat back at me. I stayed perfectly warm this way. When the wind picked up, I tucked the ends down around my head and feet. I know I would have survived without my tarp with the weather conditions that I had.
7:00am. I started taking down camp. My bivy sac rolls up quickly, and really doesn't take up much room at all. I'd like to try out a heat sheet bivy though.
The space blanket was NEVER going to fit back inside of the kit. It did however pack back down fairly small, I had enough room in my bag, or I could have put it in my pocket.
I used my now empty nalgene to carry water from the river to put out my fire. I also could have used my oven bag in my kit, or possibly my trash bag.
8:00am. Well, once I had everything packed up, and I re-natured the area, I started on my way back home. Sadly, one thing I neglected to pack was some TP! MAN did I ever have to go to the bathroom. I knew I was at least an hour from home... and I really wanted to hold it! I had a bandana in my kit that I could have used, but I really didn't want to dirty it up. So, I pushed on. I made it about half way home when my wife called to check-in, she offered to come get me,and I gladly accepted as I was already walking on roads. Nothing like your own bathroom at home!
Kit changes
I think my SAK worked well. But if I would have needed to split wood like I did, the Farmer wouldn't be able to handle to much. I would feel ok splitting just a few 1-2” sticks to get to some dry inner wood, but I'd do anything I could to avoid it. I usually carry a fixed blade in the bush, so I also didn't feel like using my new Breeden was stretching the rules. I tried to rely on my SAK as much as possible though. So, if I didn't normally carry a fixed blade, I'd probably change the SAK to a better knife, like a BK Necker.
Kit Evaluation
What gear I used the most
Light, I wouldn't have been able to do anything without this.
Ground protection!!! Things were wet wet wet. I would have been miserable without something to keep my dry. Trash bag. Siting mat. Space blanket.
Fire starting things. Ferro rod and PJCB worked great. I also had a piece of fatwood which I didn't need to use. The only thing I'm going to change as far as firestarting goes, is I've ordered a 3/8” rod to replace my 1/4” rod. The LMF firesteel has to big of a handle for my kit.
What gear I used the least
Water purification. Didn't need to use my tablets since I could boil water
FAK. Luckily didn't need anything, but I had several close calls, so I'm definitely keep these items.
Repair gear
Food procuring
Signaling. Since I wasn't lost or needing rescue, I didn't use my whistle or signal mirror. Had I become injured, they would have been very important. The space blanket would make a good signaling tool as well.
What gear I want to ditch
If I needed more space, the first items to go would be food gathering and some of my “repair” items. I had already removed fishing supplies, and I might reduce my snare wire... but I've got a little extra room so no need to reduce right now.
What gear I want to upgrade/add
Light. My little light did it's job. At bare minimum, I'm going to add some fly line backing to it for it so I can wear it around my neck. But I'd like to see about upgrading to a Petzl e-Lite. I haven't seen one of these in person, so I don't know how large they are in comparison. But having my hands free would have been a big help. Juggling the light while cooking or using my knife was a little dangerous at times.
Poncho/Tarp. Again, this isn't a PSK item, but I'd like to checkout some silnylon pocho/tarps to carry with me. There is a lot of rain here in my area, and shelter is one of my top priorities.
Heavy duty aluminum foil. For boiling water.
This isn't an item I could add to my PSK, but if I upgrade to a day pack instead of a fanny pack, I'm going to cut down a closed cell sleeping pad to fit into it. Just enough to sit on or lay under my spine, or use to rest my knees on while working on fire or other chores.
Important things learned
Conserve energy. I didn't have much to expend, which in an odd way I enjoyed since it gave me a taste of being deprived or injured in a survival situation.
Think through decisions and don't rush. My close call injuries could all have been avoided if I would have thought more carefully.
Make time goals/plans and stick to them. While I used this mainly to just pass the time, I think this would be very helpful in managing time and will power in a real situation. Whether it be time spent fishing, using a fire bow, signaling for help, etc... It would keep me on task and moving forward to what's next.
Heat loss through the ground!
Next time I go out, I'd like to take less and less gear. I feel like I overpacked slightly. I didn't need my tarp for sure. I'd also like to stay out for 2 nights. I'd like to improve my food procurement and natural shelter skills. With improvement in these two areas would complement my physical kit well.
Here is the clothing that I wore:
And here are some non-PSK items that I normally carry, and just a few extra for this special trip:
Sorry for such a long post! Forgive me for rambling as well! Thanks for the opportunity to win something, it gave me the required umph to get out and learn my kit, which is something I haven't done before. I look forward to doing this again!
Here is what my little trail looked like, it is VERY thick in this area from all the blackberry bushes.
Frosty!:
Beaver Evidence:
Great suff bro and a winning effort if I ever saw one !!!
Thanks for the great write up !!!!
That's a really good review/story man. Sounds like you had a good time and learned a lot, and it's a hell of a way to spend a night! I really enjoy reading what people find useful/useless in their kits. Rough nights have a nice way of making that decision for you!
All this threads do have me itching to take out some new [minimalist] gear for a night in the frost. Lots of stuff I need to test..
Anyway, cheers! Good goin'. :thumbup:
Rock on Naked! (that just sounds weird, huh?)
Unfortunately your wifes "best look of concern" seems to be masking more of a "what have I got myself into" kind of look. :D
Great post. Got me thinking. Especially your choice of lights.
Thanks. :thumbup:
Luke that was just awesome and WOW I like your fixed blade knife choice ;) LOL
One thing I think you should get is the Snow peak mini solo. It has a pot a little cup and a lid that will all fit under your nalgene bottle.
That what I carry and they are great.
Bryan
One of the best trip reports I have read in ages. Great stuff Naked!
That picture of the trail in the mist is great. So is the one of the frosty leaf.
I'm going to re-read this a few times before posting some substantive questions and comments.
Thanks for taking the time to share this with us!
All the best,
- Mike
Awesome post! Great way to practice your skills too. I'm with Spooky, it made me want to go light for a night :)
Hi all
Luke this is the mini solo kit I was talking about. It is a bigger pot then a smaller cup and lid.
In this pic I have then all laid out by my steel nalgene bottle.
In this pic I have then all packed up and the water bottle in the large pot and
then the smaller cup under that and that all sits on the lid.
Then I have it all packed into my nalgene water bottle carrier.
these are great for cooking in and making soups and and having several metal containers in any sitution just makes life better to my way of thinking.
anyways again great review. It is always neat to test your self and get and idea on how you might really do something if you really had to.
In the Marines we had a saying that goes "the more you train in peace the less you bleed in war". So the more you train for the outdeoors the better you will get and be better prepaired to handle a real life situiton if that happens to happen to you.
Take care all
Bryan
Bryan, thanks for posting that. I haven't seen the nesting cup/pot/lid before! I'm trying to decide if I want to stay with a nalgene or not. I don't like how they ride on my fanny pack, and I'm thinking of moving to a backpack w/ hydration pack in it. I really like that pot kit though!
Congratulations on your mission accomplished.
Great post ... very well worded and informative.
All that's missing are pics of your fire .
What the heck, a few more pictures!
This picture shows how I use the fire to dry out some other wet branches.
PSKChallenge
This makes my wood supply and fire look small, but this amount lasted me through the night, I tried to have a really effectively burning fire:
Morning fog:
I also came across this, not sure what it was. It was about 8-10' tall:
And maybe around a 100 yards long:
Excellent trip report--
Hell--- better than excellent!!!!!
More like OUTSTANDING
Thanks for taking the time and effort to do this Bro...
Did they ever do any logging in that area?
I've come across some remnants of old logging mills while out in the woods. Even found what looks like an old belt driven table saw in the woods behind where I work. I've heard it was a prison run orchard and farm some 100 years ago. Just vacant land now.
Great stuff! Very enjoyable read, I'm glad you took the time to type all that! One thing to remember before you start thinking about ditching stuff you didn't use is it's a survival kit. Just because you didn't need it on this particular overnighter on that night, don't forget you might really need some of those items to survive one day. Just my two pennies.
That is just awesome! Its threads like this that get you going. I wish I had the time to do it more than ever now, but for now I will live through your experience. Thanks for sharing your great experience. I might have to plan something in the near future. ever it just in the back yard LOL
