S30V, G-10 with liners, and a compression lock for $100ish? That's already attractive. It has that fine point which is great for precise cutting but also 4mm stock and an aggressive hollow grind that beefs up the blade. The way I use it is as an enlarged razor blade. It cuts through cardboard like nothing else, but can also be used for utility. The downsides are, you can get pinched when opening by the compression lock, and mine took a while to smooth out, I was barely able to close the knife the comp lock was so stiff. The tip also seems like a weak point, but people buy the Leek so obviously strong tips aren't important to everyone. It is also harder to sharpen than other knives on the SharpMaker because it's easy to turn that straight edge into a curve, especially at the end if you aren't consistent with your pressure. But I still love mine, an carry it regularly. It also makes a great salame slicer
I'd definitely handle one and try it out, it takes some getting used to because of the comp lock pinching your hand issue.
