Now, that is a picture that will be difficult to erase from my mind. At least use the pliers on the 91mm Mechanic, next time.I like to pull boogers out of my nose with the tweezers while riding the eL.
Next time I'll take a selfie doing it with my Leatherman Wave.
Yes, I know. I'm a horrible person. But pretty much anything goes on the eL. I like to bring a stick and poke the sleeping homeless people.
Maybe you should consider one of the custom Ti 91mm SAKs. You get metal scales and the toothpick and tweezers.
Personally, I have found the SAK tweezers and toothpick almost useless. Are you willing to use a wooden toothpick on your teeth that has been in your pants pocket day after day? If so, I guess using a plastic one under the same conditions is OK. It is kinda gross, if you ask me. There is a reason that wooden toothpicks come in plastic wrappers, folks.
The Alox series is a cut above Vic's other products. Why any SAK fan would deprive themselves of an Alox knife just because of a weak pair of tweezers and a gross, bacteria ridden piece of plastic, is beyond me.
Does it need explanation? I think it sort of says it all does it not?Please explain.
First off, it's not like I'm sharing my toothpick, if there is a little bacteria on it I'll survive. It can't be any worse than kissing someone, do you know how much bacteria is in a persons mouth? But for your information my SAK is on my keychain which is clipped to a belt loop. It's not a loose toothpick floating around in my pocket. I use the toothpick, wash it off, or wipe it off on my handkerchief if that's all that I have available until I can wash it later. I occasionally drop a little alcohol into the hole on the SAK. I also have a couple bags of replacement toothpicks so I can toss them out (or usually lose them) every few months.
But you really shouldn't stress so much about germs, if you are constantly obsessing over keeping everything around you 110% sterilized you are going to have a weak immune system.
