Ice Razor Process
This is the process of how I established a mirror finish on some INFI!
Once the black crinkle coating took a beating I decided to strip it. I've always enjoyed the look of shiny metal and a black handle.
So I used a chemical stripper, and then a paint removal pad that chucks into a drill to shine it up.
For the serrations, I used a craftsman 6in. Round File. I just marked o the blade with a sharpie where exactly I wanted them to be, and started filing. It's very slow moving at first. Only cut in a forward direction with the file! Do not drag it backwards as it flattens the teeth of the file. Once you start to form a trough in the blade, the filing becomes much easier. Later on, I widened the serrations out a bit with a small grinding stone used for sharpening chainsaw teeth. It fits right into a Dremmel. (These items were purchased at Sears, I'm sure they can be found at any other hardware shop also.)
To remove the Hell Razor bevels I needed some agressive sanding. To save me loads of time, I bought a kit from Sears that chucks into a drill. It has a black plastic disk, with which you can change grits of sandpaper.
This is a picture of the disk, and the changable pads.
This is from when the INFI dimples are gone, but the bevels aren't quite gone yet.
I started with Course Metal sandpaper.
It is important that at every stage you remove all signs of the previous cut, which will not always be easily visible. So try to make each cut cross it's previous one at 90 degrees, this way you can see the scratches. This means if you have sanding marks going from spine to blade, (like the pic above) then when you move up to a higher grit be sure to sand from handle to tip. And do not move up grits again until all of the pervious scratches are removed. It is easy to see them by looking into the reflections in the knife.
I used the course sandpaper until all of the larger scratches and pits were removed, then I moved up to the Medium and Fine Metal sandpaper. Again going at a 90 degree angle with each new grit from the previous cut. Then I moved up into 800 grit Wet/dry sandpaper. This can be found at most autoparts stores. Then from 800 to 1500, then finially to 2000. With each of these last three pay close attention to how easily they lose their "roughness". You should find yourself going through wet/dry paper much more quickly than the heavier grits. Be sure you're not wasting time with a piece of sandpaper that isnt removing any metal because it is wore out or clogged.
Once you reach 2000 grit, it is basically a mirror. It still has some haze to it though. Take it to a buffing wheel on a bench grinder with some Fine compound, and it will take the haze right out of it! If you dont have access to a bench grinder. Sears sells mini buffing wheels that will chuck into your drill and get the job done!
This site offers some great tips as well.
http://www.englishcustompolishing.com/usca/stainless.html
Remember, don't rush your work. It will show!
Here's a pic where the bevels are gone, but it's still not fully polished.
Very cool, dont know if I am brave enough to try it but that was very informative.
Thanks for sharing
BTW... excellent job
WOW!!
That's some nice work!! That Ice Razor looks awesome.
Regards,
Nick
Most excellent work:thumbup:
With that mirror finish, it's like the blade turns invisible and your eye just sees the reflections:eek:
Definetly loving it. I will have to get a buffing tool soon.
BTW, what make is the smaller knife? I want one now :P
EDIT: Ice Warden, got it.
Man that stuff shines up nice! Thanks for the lesson.:thumbup: :thumbup:
Very good post. Thanks for the info.
The Ice Warden in the moss is practically camoflauged.
Very cool, and thanks for the info. This would indeed look very cool with an AK, or would look great on a CG FBM for everyone who wants one, but doesn't care for the bevels. I know it's just a matter of time.
very nice work but... how much does it cut into your drinking time and secondly what would you charge to do 300 wardens :confused:
You could always hunt down a Mud Razor that doesn't have the CBT. :D I have thought about that a few times.
This is my plan... bought a used MR and plan to let her run nekkid!!
Thanks again for the details Gunsite... VERY COOL WORK!!!
I once had to strip an 8 foot tall silicon bronze sculpture that was coated with spar urethane with that jasco paint remover. I gotta say, I hate that stuff!
it does work great though. and I gotta say, that mirror polish looks like its well worth it!
i ran out of pigs nose once and used that stuff in a 50/50 dilute with water, not to bad and even cleaned the tarter from my teeth :thumbup:
Geez Skunk didnt your mother tell you to never dilute with water. Your supposed to jus' let the ice melt.:D
