For anyone that uses Brownell's acraglas epoxy and needs to mix small amounts this is a method that we have found to be accurate and it saves wasted epoxy. It is just two marinade injectors that have been marked with a 1/8 inch scale on the side and filled with the resin and hardener. Grind off the sharp end of the needle and save the point protectors the injectors are shipped with. Seal one end of the point protectors by pinching with a dab of superglue, acts as a great cap for the injector. Hope some of you can use this idea. It is saving us a bunch of epoxy.
