I owned a Cold Steel Trail Master once upon a time. Why I bought that I don't recall. Your design isn't similar, in any way, shape, or form, to that tool. It was definitely a tool that could be used as a weapon, I suppose, but a camp knife style tool first and foremost. I used that Trail Master one day to cut some heavy brush in the yard and never "used" it again btw. I wound up giving it to a prepper friend who was thrilled to receive it. I have a WW II Camillus folding machete that works much better for yard work my wife tells me...............
I looked at your blog and got the idea that you make props. If the knife you designed is to be a prop you can make it out of just about anything: cardboard, wood, plastic even metal. Hell make it out of wood and wrap aluminum foil onto it or paint it with "hammered" spray paint. No need to heat treat it. No need to use micarta for the handle. You could use Sugru (an air curing rubber) and have a dandy, customized grip in minutes.
But if you're going to make a knife to use for something you might wanna contemplate the end use. Your design incorporates a pommel spike. Why do you need that? A pommel that you can use to hammer with might, actually, be useful for something. A spike implies to me that this is a fighting knife. Fighting knives are used for stabbing and slashing people. The spike would be used for a temple strike............. If you do a search and study some classic fighter designs, you'll see that they are a lot thinner, frequently double edged, fast looking, and in cases like the Gerber MK. II useless for pretty much anything except dealing out death. Admittedly many styles of Randalls, Beckers, Esees, and Lile Rambo-style knives have other uses than mayhem but they are,basically, quiet and formidable weapons.
You had some serrations in your design. Useless and a lotta work to sharpen. They're in the wrong place and diminish the length of useful cutting edge IMHO. Serious saw teeth ala The Randall Model 18 or Lile's Rambo knife are on the back of the blade and a good 5" long. Those were originally designed for cutting through a thin, aluminum, helicopter fuselage to escape after a crash, not to saw wood btw.
If chopping/batoning is your intended use, save yourself a great deal of pain and get a small camp axe designed for chopping.
A flat grind on such a wide blade is more suited to a kitchen knife. A hollow grind would be a lot stronger (of course it's tougher to do without a good grinder you couldn't really file in a hollow grind). Incorporating some ergonomic curves into your design mind make it a bit prettier too.............
I think you should scrap this design and start over with a blank sheet of paper myself, listing out, first, what you really wanna use it for.
Corey "synthesist" Gimbel
