- Aug 31, 2017
Topic says it all, but I'll buy one of them suckers and experiment. That is if the companies stop painting them all in red like many are currently doing. Maybe get the Spydie Mule in it.
Brilliant post and the answer I was looking for.S110v will outperform magnacut in terms of edge retention, but magnacut is tougher and more corrosion resistant. Depends on what you mean by better.
I was thinking it would be a straight upgrade of s110v (2010), as all the metrics we measure alloys on would possibly see an increase of 5~20%.It isn’t “better”, it isn’t “worse”. It’s “different”. Different steels, different pros and cons.
If you want an upgrade, you will need to think about what you desire. Do you want better edge retention or better cutting ability? Get a thinner blade. Geometry is very important. Do you want corrosion resistance? Well, Magnacut probably does have S110V beat. Toughness? Well Magnacut is undoubtably tougher than S110V on paper, every maker will make steels differently somewhat, so that also plays a role. A thicker blade will undoubtably be tougher than a thinner one though, geometry matters. I would encourage you to think about these factors, Magnacut is probably going to be an upgrade across the board, including like Alberta mentioned the ability to sharpen the steel easier.Brilliant post and the answer I was looking for.
Magnacut is the latest fad steel, it's not necessarily better in every way. It has a lot of desirable qualities and will likely stick around, but a lot of what you're hearing is hype. Steels like Elmax and S110V were once the flavor of the month but are rarely seen now.
S110V is kind of an odd one. On paper it should have better edge retention than S90V since it has more carbides, but due to a variety of factors it didn't perform as well in real world situations. It's far harder to sharpen, chips more easily, and quickly loses a keen edge in favor of a toothy one. So in actual use, many people found their S90V knives performed better, and now you don't see a whole lot of knives in S110V. It was too specialized.
I suspect Magnacut will stand the test of time much better than S110V did because it's very well balanced. Depending on how you heat treat it, you can bring out qualities that are ideal for the majority of users. Soon enough the excitement will die down and people will need something new to chase, but Magnacut will still be a great steel. 154CM, for instance, is practically ancient but still very well liked due to the balance of positive attributes.
Some good points here, but wanted to mention that when you compare s110v to s90v, you need to control for carbide type and size, as well as working hardness. Carbide volume does not end the conversation, carbide size, carbide type (i.e., vanadium as opposed to other carbides), as well as how steel formulation affects achievable hardness must all be considered. I know this does not necessarily contradict your point, but thought it was worth mentioning. FYI, I am no expert, I just read a lot; BBB offered some commentary on this exact point in his latest instagram post.Magnacut is the latest fad steel, it's not necessarily better in every way. It has a lot of desirable qualities and will likely stick around, but a lot of what you're hearing is hype. Steels like Elmax and S110V were once the flavor of the month but are rarely seen now.
This is a great point that I'm surprised people don't know, albeit not related to the thread. s90v from Spyderco is probably better that S110v from the same manufacturer. It's such an odd duck since 420v came out a decade before s110v and just is plain up better aside from cutting a zillion things, it will cut a zillion -1 and s110v a zillion +1.S110V is kind of an odd one. On paper it should have better edge retention than S90V since it has more carbides, but due to a variety of factors it didn't perform as well in real world situations. It's far harder to sharpen, chips more easily, and quickly loses a keen edge in favor of a toothy one. So in actual use, many people found their S90V knives performed better, and now you don't see a whole lot of knives in S110V. It was too specialized.
But the S110V toothy edge holds F O R E V E R ...
S110V is very stain resistant. Better than 20CV, for instance. MC more so, but the difference is subtle.
It comes down to edge holding vs. toughness, in practice. Note, that CPM Cruwear is tougher than MC. MC is similar to M4 or V4e, just stainless. I take Cruwear over all the others, and I have MC knives. But i’m not a diver.
If magnacut can part steel better and can do more cardboard and paper shreds without needing any work done on it, then s110 is beaten. I just need to see it in one of my go-to knives or something interesting for me to bight.
What do you mean? Do you use S110V for machining or do you mean you use S110V on paper and steel parting at your work as a edc knife task? If that's the case, what is steel parting?This is a great point that I'm surprised people don't know, albeit not related to the thread. s90v from Spyderco is probably better that S110v from the same manufacturer. It's such an odd duck since 420v came out a decade before s110v and just is plain up better aside from cutting a zillion things, it will cut a zillion -1 and s110v a zillion +1.
I also want to add that I use s110v for paper and steel parting at the micro-maching shop. If magnacut can part steel better and can do more cardboard and paper shreds without needing any work done on it, then s110 is beaten. I just need to see it in one of my go-to knives or something interesting for me to bight.
304L steel for hardening/tempering later, brass, or bronze. You turn the metal in a lathe or mill and part the piece you make.What do you mean? Do you use S110V for machining or do you mean you use S110V on paper and steel parting at your work as a edc knife task? If that's the case, what is steel parting?
Try a CPM 15v knife. Just keep it away from salt water.If magnacut can part steel better and can do more cardboard and paper shreds without needing any work done on it, then s110 is beaten. I just need to see it in one of my go-to knives or something interesting for me to bight.
