...steel frame...
Well, I can't argue specifics on the back-lock. I just grew up with them and they served me well. Never had a failure and are truely ambi.
lockbacks seem prone to collecting junk in the lock have a significant amount of drag so it's harder to flip or flick the knife open. not something you really need to do, but lots of buyers seem to like something they can flick open.
Riveted construction makes it impossible to remove 100% of the accumulated dirt in any folder. Unlike frame locks and liner locks, lock backs will not fail when twisted. Lock backs are also very wear-resistant. A three-sided tooth on the rocker bar nests in a three-sided recess on the blade; resulting in full engagement of the lock every time. This is not the case with frame locks and liner locks.
I'm a lefty, a proud member of the superior minority,
I like to be able to open and close with one hand, thus the reason there are other locks better for me than the lock back. Sometimes I'm holding something with one hand and need to get a knife opened.
Difference in weight between the steel frame model and the ti frame model is .8 ounces (less than an ounce). We have one of each and weighed them both on a postal scale.
I couldn't care less if it's steel or Ti.
Ti has an undeniable cool factor but I don't think it really offers any advantages over steel aside from weight.
frame locks are generally stronger than liner locks due to more surface engagement.
Because there is more surface area in contact (except when compared to the beefiest liner locks), the lock surface area will wear slower.
In addition when in use, your grip will help the lock stay closed, even under heavy use.
However, the STRENGTH of the framelock is the the crossection of the thinnest part of the locking bar, where it is partly milled away, and pre-folded inwards. This cross-section is often comparable to that of strong liner locks.
